Snow Blower chute controls
/ Snow Blower chute controls #1
PeterK
Central Maine
Kubota BX24 TLB
Sorry. I just spent too a lot of time writing a description and lost it when I went to add the image. So all you get is the image since I don't have the time to do it all over again. I will look back and respond later, too busy this am. This schematic will control one axis so you will need two to control both the left-right and up-down.
If you don't already have electric motors to control the chute, search the forum. This is just for controls.
I had been using DPDT momentary rocker switches and they work great, just not at my finger tips . So this prompted me to use some sort of 4-way SPST switches that I could mount on the loader control lever. I ended up using a 4-way joystick from eBay. It has 4 individual micro switches which are perfect for the task of switching the ground to the relay coil. I will mount it in a small project box and attach that to the loader arm. It needs 5 small wires to complete the ground (which energizes the appropriate relay by completing the power circuit to the relay coil.)
I am using Bosch 5-pin style relays and dual sockets from http://www.PartsExpress.com They're high amperage, actually much overrated for the window motor that I am using for rotation. But easy to find and reliable. You can also get waterproof relays if you think that you will need them. The 4 relays and fuse will mount to the left side of the center console support. Might even add an aux fuse panel if I find enough room in there.
On the business end of the wiring, I use WeatherTec connectors which plug into the harness from the blower. Makes R&R easy and these are weatherproof, important since they are outside in the elements.
Anyway, hope this schematic helps. There is a lot out there but no real wiring diagrams that I found so here's mine:
/ Snow Blower chute controls #3
Clean and simple and inexpensive. I did much the same. Nice job.
/ Snow Blower chute controls #4
I had made the cab many years ago, now with the blower it's great. Also added heat and back up cam. Snow Blower.jpg
Tree Boom Mini Skid Steer Attachment (A64553)
Tree Boom Mini...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
Rooster Weather Vane (A64557)
Rooster Weather...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
