Snap up bracket question.
/ Snap up bracket question. #1
wilnis
Since I got a TN60A tractor last summer, I "had" to buy a new trailer to haul it around. I got a 12,000# capacity Mustang and have a question about how to use my weight distribution hitch. The snap up brackets have a capacity of 2 1/2" which fits fine over the L shaped angle iron front that extends to the hitch on the horse trailer I currently use it on, but the new trailer has I beam front bars, 8" high and 4" wide so the brackets won't fit and the "I" shape makes it so there is no place to brace the brackets. I'm open to suggestions, Please, and while my skill set does not include welding at this point, I have a buddy who is a pro and would help. Thanks-Bill
/ Snap up bracket question. #2
You might check with a camping trailer dealer who sells WD hitches with your situation. Maybe he sells the snap up brackets that will fit your trailer frame. If not I'm sure your welder friend can adapt your existing brackets to fit the I-beam trailer frame by welding in a piece of C-channel to take up the gap. You might be able to drill down through the frame top and bolt your existing brackets in place. If the correct brackets you need aren't readily available thats what I'd do.
/ Snap up bracket question. #3
If you have to drill on the frame, you should drill on the side and never on the top or bottom.
/ Snap up bracket question. #4
Boomerang,
Just a question as to why not to drill on top or bottom? He has an I-beam type frame. I don't see were a couple of 3/8" holes to mount something would affect the structural strength of the frame. What is your thought on this?
George
/ Snap up bracket question. #6
You should always drill or weld through the web on a frame and not the flange. There is a lot of stress on the flanges and you could weaken the frame. It is the same reason why you should never weld on the top of an axle tube. You may be ok doing so on a light duty trailer or truck with a mild steel frame but never on a high carbon steel frame.
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
300 gal Fuel Tank (A66408)
300 gal Fuel Tank...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
