Snap ring size?
/ Snap ring size? #1
GatorDawg
Lake City, Florida
Mitsubishi D2350
I'm trying to figure out what size snap ring I need for the input shaft on a Howse 500 rotary cutter. Bought the cutter used and noticed it was missing the snap ring when I was inspecting it prior to using. I can find the part online and also in parts diagrams/lists, but it does not give any specifics on size. I'm hoping to be able to pick one up locally (TSC) so I can mow.
Thanks for you time and help in advance.
/ Snap ring size? #2
If you didn't find the snap ring already, go to: www.howseimplement.com. They reference E46 snap ring that looks like what you need.
You might find another rotary cutter by a different company that uses the same gearbox as your Howse.
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
J.I. Case 2090 Tractor (A66285)
J.I. Case 2090...
2022 EZ-GO ELITE...
2014 CHEVROLET 2500 SERVICE TRUCK (A64278)
2014 CHEVROLET...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
