Smooth loader bucket vs stump
/ Smooth loader bucket vs stump #41
Weights put the weight on the tractor, fluid puts the weight on the ground.
I think I'm going to start a stump bucket thread since that is what this turned into and I can't find any decent ones on TBN. I thought about getting a stump bucket a long time and the opinions are very polar. I think there are good reasons why the are polar and we need a thread that explains those reasons so those thinking about a stump bucket have a good source to inform their decision.
/ Smooth loader bucket vs stump #43
I wonder if this would work on my tractor loader ??? I have an Kubota 1153 loader on a Kubota M7040... Loader has the quick attach...
Considering that your tractor is heavier than mine it should have no problem pushing a stump bucket into the ground. I don't know anything about the curl cylinder on your loader. Given the size of the tractor I would think they are decent, but this is just a guess. Do you have specs on the loader especially curl force? Alternatively if you have curl cylinder specs (length, diameter, rod diameter) and the hydraulic relief pressure setting on you loader we'd have an idea of how strong the curl is. I'm guessing it would work fine. Just don't drive forward with the bucket tilted all the way down into the ground.
I just started a new thread on stump buckets. You might want to join that discussion.
38" FIRE PIT RING/DISK (A64281)
38" FIRE PIT...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2016 Ford F-150...
(4) MOUNTED 2000 LB TRAILER JACKS (A64280)
(4) MOUNTED 2000...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
2014 INTERNATIONAL DURASTAR 4300 EXT CAB DUMP TRK (A64280)
2014 INTERNATIONAL...
