smith torch problem
/ smith torch problem #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Last time I was doing some gas welding with my smith AW-1 aircraft torch, the handle was getting so hot that I couldnt touch it without a glove, or it would burn me. The handle on my blueshield torch has never got hot to the point where I couldnt hold it, so I am sure there is something wrong with my smith. I wont be able to check anything on it for a week or so, but I would be happy to hear any ideas.
/ smith torch problem #2
Replace the "O" Rings. Had a Smith cutting torch that did the same. Had to hold it with a hot glove. Burning inside the handle is the cause. New "O" rings should fix it up.
Ok I guess I will have to stop by air liquide soon and get some new O rings. Could it have cause damage to the torch? Also, is changing the O rings something I can do my self, or should I let the lws do it?
/ smith torch problem #4
Yea, have had to replace a few as well, easy fix, unscrew the tip and roll on the new ones.
Ok so it sounds like something I can do my self, I will do that before I light it up again.
x (A68191)
x (A68191)
WEATHER GUARD TOOLBOX (A68842)
WEATHER GUARD...
Front Tank Bracket (A64126)
Front Tank Bracket...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
PRESSURE WASHER (CONDITION UNKNOWN) (A68842)
PRESSURE WASHER...
PORTA POTTY (A68842)
