smith torch problem
/ smith torch problem #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Last time I was doing some gas welding with my smith AW-1 aircraft torch, the handle was getting so hot that I couldnt touch it without a glove, or it would burn me. The handle on my blueshield torch has never got hot to the point where I couldnt hold it, so I am sure there is something wrong with my smith. I wont be able to check anything on it for a week or so, but I would be happy to hear any ideas.
/ smith torch problem #2
Replace the "O" Rings. Had a Smith cutting torch that did the same. Had to hold it with a hot glove. Burning inside the handle is the cause. New "O" rings should fix it up.
Ok I guess I will have to stop by air liquide soon and get some new O rings. Could it have cause damage to the torch? Also, is changing the O rings something I can do my self, or should I let the lws do it?
/ smith torch problem #4
Yea, have had to replace a few as well, easy fix, unscrew the tip and roll on the new ones.
Ok so it sounds like something I can do my self, I will do that before I light it up again.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2025 Mini Excavator Attachment Set (A66734)
2025 Mini...
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
DEERE 544K Quick Attach Coupler (A68134)
DEERE 544K Quick...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
CAT 416B Front Loader Bucket (A68134)
CAT 416B Front...
