smith torch problem
/ smith torch problem #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Last time I was doing some gas welding with my smith AW-1 aircraft torch, the handle was getting so hot that I couldnt touch it without a glove, or it would burn me. The handle on my blueshield torch has never got hot to the point where I couldnt hold it, so I am sure there is something wrong with my smith. I wont be able to check anything on it for a week or so, but I would be happy to hear any ideas.
/ smith torch problem #2
Replace the "O" Rings. Had a Smith cutting torch that did the same. Had to hold it with a hot glove. Burning inside the handle is the cause. New "O" rings should fix it up.
Ok I guess I will have to stop by air liquide soon and get some new O rings. Could it have cause damage to the torch? Also, is changing the O rings something I can do my self, or should I let the lws do it?
/ smith torch problem #4
Yea, have had to replace a few as well, easy fix, unscrew the tip and roll on the new ones.
Ok so it sounds like something I can do my self, I will do that before I light it up again.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
335 GAL WATER TANK (A68842)
335 GAL WATER TANK...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
25060CFL (A64557)
25060CFL (A64557)
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
