Smart Shop tips!
/ Smart Shop tips!
Yep, that should work OK.
I also use it to renew yellowed headlight lenses. There it does great. (you wonder where the yellow went)
LOL, in a pinch toothpaste and elbow grease will also do the trick as it is an ultra mild abrasive.
I use 'Barkeeper's Friend' but I am looking for something a little more effective.
/ Smart Shop tips! #182
I know what DOESN'T work is the specialty kits they market to rejuvenate headlight lenses.
/ Smart Shop tips! #185
I put Dymo date labels on my flashlights and multi-meters when I change the batteries.
Leaving old batteries in a MagLight until they go bad and swell up is a pain.
Same in other devices when they start to leak. Good or bad, they get changed at least every year.
/ Smart Shop tips! #186
81dkQzyjkqL._AC_SX679_.jpgu
One of these make a lot of Shop Tasks much easier. Great for brake work and it's height adjustable. The bottom tray is handy and is removable.
/ Smart Shop tips! #187
Take a worn out reciprocating saw blade and grind/file the teeth off so it is sharp like a knife.
Chuck it up in your saw and use it for cutting down large boxes and Styrofoam packing.
It doesn't leave a mess on the floor like a blade with teeth does.
/ Smart Shop tips!
This is interesting! Any before/after pictures? Are you saying to grind the teeth to a V?
/ Smart Shop tips! #189
/ Smart Shop tips! #190
Put 2" of concrete in bottom of mine. If bucket tips over all of the separated junk immediately gets sucked into vac.
That's a good idea. I just have 1 screw holding mine to the wall because I didn't want it falling over either. I've been using mine for 5 or 6 years and my vacuum filter is still spotless.
/ Smart Shop tips! #191
Maybe it's just me... but I"ve tried a half dozen "magic formulas" to clean yellowed headlight lenses; none were cheap either. None worked well! And I refuse to pay some oil-changing operation $25 each to clean mine - especially when they just wipe WD40 over it. That's gone inside of a day. My solution was to simply replace mine with new assemblies with better bulbs. Simpler and it works.
/ Smart Shop tips! #192
I made a couple mini squares from standard speed squares, to use in wood or metal working shops. I made one from plastic and one from aluminum and both work really well. I found myself reaching for one much more than I expected, so I made another aluminum one to keep on my bench in the barn. I use the cheapest speed squares I could find, in the $2 range. Most of the better brands have more slots for options, and those slots make them unusable for this. I attached pics of the new square with a red line indicating where I'll cut it with a hack saw. Then a pic of it cut. And finally the mini square. I clean up the fresh cut edge with a file, as well as any burrs on the other edges. This last one took me a total of 2 minutes to cut and file. By looking at it, you wouldn't think it makes much difference to have a standard or mini size, but that smaller size can be used easier in tight areas and also fits in a large pocket.
I think you can buy those that size already. I know I have a small one that I know I didn't cut.
/ Smart Shop tips! #193
WD-40 cleans all that gooey adhesive that they stick labels on with.
To save sandblasting the widow in a sand blast cabinet stretch some black widow screening over the inside of the window, attach with duct tape.
Duct tape will also protect glass from sand blasting, like on a window frame or such.
That same tape does a fair job for when paint stripping also, but aluminum foil tape is the best.
Aviation uses foil tape on plexiglass when they paint strip aircraft.
Another recent discovery.
Fine auto body rubbing compound does a super job of cleaning up baked on gunk on stove tops and oven doors.
And vise versa. I buffed out my car just prior to the big house building project, you wouldn't know it now.
It was so bad i used the compound you buy to clean the surface of your electric range. Then work your way back to regular compound.
Works good!
/ Smart Shop tips! #194
p
I bought a product at autozone or somewhere for polishing your headlight lenses, like a kit. BMW dealer wanted $150 each.
It took a LONG time but in the end, almost perfect. Do one completely then look at the difference.
You could probably cobble something together yourself, it was 90% rubbing and 10% compound.
/ Smart Shop tips! #195
My solution to lost and wandering tape measures.
Frequent visits to harbor freight whenever they had coupon for free tape measures (not the best quality but good enough for most work and at the right price) I ended up with a toolbox drawer full of tapes (pre-COVID. No more free coupons that I’ve seen). Now when I start a project I grab a tape from the drawer. Multiple projects... multiple tapes.
As the projects get finished, sometimes the tapes make it back to the drawer, sometimes not. When the drawer is empty, it’s time to clean up the shop and find all the lost tapes.
It’s easier done than this write up.
/ Smart Shop tips! #196
3M rubbing compound works great.......looks like new, and cheap fix!
/ Smart Shop tips! #198
"To save sandblasting the widow in a sand blast cabinet stretch some black widow screening over the inside of the window, attach with duct tape."
used to build sandblast cabinets for the local hotrodders. They needed cabinets that could hold a door or trunk lid.
The BEST fix for protecting the glass was a roll of Mylar. Held up great and never replaced a glass again.
/ Smart Shop tips! #199
Gonna have to try that, thx.
/ Smart Shop tips! #200
I had a great visionary experience the other day while trying to squirt some foam sealant in spots that the supplied tube wouldn't allow me to reach. I went to my container that holds all kinds of spare straws, tubes, etc and found one that came close to match the one I needed to extend.
I fired up the hair dryer and heated it enough that I was able to force the factory one into it. Held it for a minute, and Voila. Extended snout and something to shout about.
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
John Deere 302A 50HP Front Loader Utility Tractor (A61572)
John Deere 302A...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
Kuhn FC400RG (A60462)
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
