Smallest Kioti for sqaure baling?
   / Smallest Kioti for sqaure baling? #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
I'm leaning real heavy toward a Kioti tractor and I just wondered what's the smallest one you'd feel comfortable sqaure baling with? No hay wagon, just the baler. Definately gonna be a 4wd. Most all land is flat or slightly rolling with a few steep places. I am currently doing all my hay work with a 1975 Massey Ferguson 135. DK 40 or DK 45?
   / Smallest Kioti for sqaure baling? #2
definately a DK. 40 will probably be ok. What baler will you be using and what is it's PTO requirements ?
   / Smallest Kioti for sqaure baling? #3
Hi
I have baled hay with a Ford Super Dexta, i think for memory they were 45hp. I have also baled hay with many other much bigger tractors. This experience has showed me the bigger the HP the better the bale makeing. With the smaller tractor sometimes you get a fluctuation in engine RPM and many balers under these conditions the knoters start to not tie properly.
   / Smallest Kioti for sqaure baling? #4
We have run our JD kicker with a Farmall A. As long as the baler has a flywheel, it will overcome the horsepower deficiency. Remember, the plunger arm will rock the tractor back and forth, so you will feel it.
The baler I am currently using is a IH McCormick model 46. We have discussed buying one a lot newer and more reliable so I can buy a used baler that will fit the tractor later.
   / Smallest Kioti for sqaure baling? #7
We have a well used 334 JD. I think it's ran about 500,000 bales. We took the hydraulic kicker off because it's so dangerous. As long as you keep the knotters clean and oiled and a machine greased, they run a long time. Basically what screws up a kicker bailer is the bushings that are in the needles and knotter wear out and the slop will cause a mis-tie. The factory bushings are steel. I have machined new bushings and inserted a bronze bearing. They last much longer that way.
I don't know much about Kioti's, except that they are orange, like Kubota. I would get a minium of 40 pto horsepower, however. At least then when the hay gets "tough" you won't work the tractor real hard. Another thing, you will need at least 40 pto horses if in the future, you decide to round bale.
You really think 40 pto hp will round roll? I looked at some specs on those small round rollers and they say 35 pto hp, but I have a hard time believing that. I may want to round roll in the future so that's a real consideration.
   / Smallest Kioti for sqaure baling? #9
Yep.
I used to do it with a 3710 Kubota. That is 32 pto. I upgraded to a 5030. The HSTC is 42.5 pto. Enjoy the pictures.
   / Smallest Kioti for sqaure baling? #10
Here is another. The tractor is not really working hard. The ac is great!! This picture is worth a thousand words. Needless to say, I am not getting covered with chaff and the stereo is great. /forums/images/graemlins/smirk.gif
   / Smallest Kioti for sqaure baling? #11
It takes quite a bit less power to square bale than to round. The square baler has a flywheel and the inertia of that flywheel carries the bailer through it's cycle. A round bailer, however, has no flywheel. As the bale nears full size and weight, it takes more and more power to roll it within the bale chamber.
   / Smallest Kioti for sqaure baling? #12
Re: Smallest Kioti for square baling?
(click on picture to enlarge)
Hesston 730 Round Baler requires a minimum 30 PTO hp tractor.
I had seen this hooked up to an Agco ST45 Compact Tractor at Empire Farm Days…
(I'll try to post some pictures later)
   / Smallest Kioti for sqaure baling? #13
John:
Looks like my 645 NH in the previous picture. Except it's not dirty. Here is a "clean" picture
They mean "minimum 30 pto hp." It takes every bit of that to roll a maximum weight and diameter bale.
   / Smallest Kioti for sqaure baling? #14
I answered the mis-tie in a later post. The rpm fluctuation causes the needles to fluctuate all the more, especially if they are worn.
   / Smallest Kioti for sqaure baling? #15
Well, is NH made by Hesston or is Hesston a NH... or is everything in the world becoming homogenized to be the "same"... /forums/images/graemlins/confused.gif
   / Smallest Kioti for sqaure baling? #16
John:
Manufacturing in this country has become multinational . I may need correction on this but I think NH is Fiat. I wonder if Ford still has a part of it or a part of Fiat as I can "A" plan NH equipment. I think that hesston is AGCO. Tractors and implements are getting like mouthwash, they all come out the same spout and have different labels put on them!!!
207272 (A52708)
207272 (A52708)
2007 KUBOTA KX121-3 SUPER SERIES EXCAVATOR (A60429)
2007 KUBOTA...
2005 John Deere 7320 (A60462)
2005 John Deere...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
