Small project
/ Small project #1
plastikosmd
Broken screw on a Winchester
Weld a small 10-32 nut to the flush broken screw
And out
/ Small project
Sorry, had to mig, pulsed mig at 85 for wire speed. Drop wire though nut touching broken screw and pull trigger. That way I did not knock nut out of line
tig tank was empty, and arc =I am not that good on a little 10-32 nut
/ Small project #4
Good that you got lucky on that one. I rarely work on parts that small, but quite frequently have people bring me broken bolts to machine out after they've tried welding it and made a big mess of the job.
/ Small project
I am the opposite
I ruin many more threads drill/pick/chase than I do welding.
I use drill as last resort.
It is easier for me to be exact w weld than center punch.
Weld is pretty easy, just don稚 weld nut or broken fastener to workpiece!
If i have to drill and screw up=Not a big deal just results in larger hole and new threads but friend had already bought correct screw and I didn稚 feel turning a task into a project.
/ Small project #7
The trick to successful drilling is to use a milling machine.
The problem with welding a nut on is that although it often works, if the threads are galled it is 100% guaranteed that it won't. And then you've hardened the end of the bolt you now need to drill out anyways.
The best is when someone drills, breaks an EZ OUT, welds a nut over that, breaks the nut off, and then gives up and brings it to me....
/ Small project
^ well with that mess I would just use my spark eroder. Good for blasting out that hard ez or handy for taps. When the part is softer than the broken piece you do need rigidity. I agree and got mills for that although for drilling, I love my little jig bore. Great sensitivity and x/y in tenths. For powering out something big, sure slap it on the mill.
/ Small project #9
That's exactly what I did actually.... I have an old sinker EDM in the corner that mainly gets used for that sort of job.
/ Small project
Ya, thinking of selling mine. I just don稚 use it enough. Cool little hansvedt
/ Small project #11
Probably the same little hansvedt I've got.... I keep it around just because I wouldn't get enough for it to offset needing it once every couple years.
/ Small project
Manual feed, I seen one w auto feed.
I had an article somewhere on how to make it auto feed
What fluid do you use? I had some edm fluid that was great. It went bad and it is hard to buy a gallon. I tried deionized water but I didn稚 like it
/ Small project #13
Mine is auto down, manual X and Y
SM-150B is the model.
Perhaps a size up from yours... I have rustlick EDM250 in it currently. Mainly because it's what I could get. Capacity of it is somewhere around 30 gallons
Most machine shop suppliers should sell pails of it.
/ Small project #14
Its a fireproof oil similar to transformer oil.... Likely was also PCB based back when
/ Small project
Mine is just a portable unit, small benchtop thing or can use under the hood or in the field if u make a small dam using clay to hold the fluid
/ Small project #16
That sounds incredibly useful....
Mine is a floor model sinker EDM that you are limited to what fits in the work tank
(INOP) 2011 FORD F-150 XL SINGLE CAB TRUCK (A59823)
(INOP) 2011 FORD...
BOX BLADE (A58214)
BOX BLADE (A58214)
2021 Kubota SSV65 Compact Wheel Loader Skid Steer (A59228)
2021 Kubota SSV65...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
Madvac CS500 Sweeper (A61166)
Madvac CS500...
