Small project
/ Small project #11
Probably the same little hansvedt I've got.... I keep it around just because I wouldn't get enough for it to offset needing it once every couple years.
/ Small project
Manual feed, I seen one w auto feed.
I had an article somewhere on how to make it auto feed
What fluid do you use? I had some edm fluid that was great. It went bad and it is hard to buy a gallon. I tried deionized water but I didn稚 like it
/ Small project #13
Mine is auto down, manual X and Y
SM-150B is the model.
Perhaps a size up from yours... I have rustlick EDM250 in it currently. Mainly because it's what I could get. Capacity of it is somewhere around 30 gallons
Most machine shop suppliers should sell pails of it.
/ Small project #14
Its a fireproof oil similar to transformer oil.... Likely was also PCB based back when
/ Small project
Mine is just a portable unit, small benchtop thing or can use under the hood or in the field if u make a small dam using clay to hold the fluid
/ Small project #16
That sounds incredibly useful....
Mine is a floor model sinker EDM that you are limited to what fits in the work tank
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Takeuchi TB016 (A53317)
Takeuchi TB016...
1770 (A58375)
1770 (A58375)
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2020 DRAGON ESP...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
