Small project
/ Small project #11
Probably the same little hansvedt I've got.... I keep it around just because I wouldn't get enough for it to offset needing it once every couple years.
/ Small project
Manual feed, I seen one w auto feed.
I had an article somewhere on how to make it auto feed
What fluid do you use? I had some edm fluid that was great. It went bad and it is hard to buy a gallon. I tried deionized water but I didn稚 like it
/ Small project #13
Mine is auto down, manual X and Y
SM-150B is the model.
Perhaps a size up from yours... I have rustlick EDM250 in it currently. Mainly because it's what I could get. Capacity of it is somewhere around 30 gallons
Most machine shop suppliers should sell pails of it.
/ Small project #14
Its a fireproof oil similar to transformer oil.... Likely was also PCB based back when
/ Small project
Mine is just a portable unit, small benchtop thing or can use under the hood or in the field if u make a small dam using clay to hold the fluid
/ Small project #16
That sounds incredibly useful....
Mine is a floor model sinker EDM that you are limited to what fits in the work tank
2019 Kenworth T880 Tri-Axle Dump Truck (A59230)
2019 Kenworth T880...
2021 International RH163 T/A Day Cab Truck Tractor (A59230)
2021 International...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
207283 (A52708)
207283 (A52708)
206320 (A57192)
206320 (A57192)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
