Small issues on TC33D
/ Small issues on TC33D #1
Breech
Southern PA
2002 NH TC33D - Replaced a 1950 Ford 8N
Good morning,
2 small issues have arisen that I am curious if they are concerns:
1. Console between the steering wheel and hazard light button cracked. Easy to fix with JB Weld or something similar?
2. Temp Gauge is not working, never moves upwards (plowed snow for a few hours and still nothing moved). Is this something I should fix or just watch?
- I seem to remember seeing this is widespread and of no concern, but cannot remember.
Thank you all,
John
/ Small issues on TC33D #2
Good morning,
Thank you all,
John
The temp gauge should be repaired. Check the wiring to the temperature sensor, and the sensor itself.
Overheating is a good way to force another upgrade.
/ Small issues on TC33D #3
I'd either be repairing that temperature gauge or replace it with a standalone gauge to prevent overheating your engine.
/ Small issues on TC33D #4
As far as the dashboard if it’s plastic you might consider plastic welding it. You can buy a kit at Harbor freight or Amazon.
/ Small issues on TC33D #6
You need to confirm that the thermostat is working properly and not stuck open. Usually done with a infared thermometer or a long stemmed thermometer in the radiator cap. If it is warming up, then check the wiring between the dash and the sensor, near the thermostat.
/ Small issues on TC33D #7
I believe you can jump the temp sensor wire to ground and the gauge should move. Free test that you don't even need to start the tractor to try. You do need to turn the key though.
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
TAKEUCHI TL6R SKID STEER (A65053)
TAKEUCHI TL6R SKID...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
