Buying Advice Small Cab Tractors
/ Small Cab Tractors #1
Olympus
Platinum Member
Cape Girardeau, MO
LS R3039
I’ve been debating on getting a small cab tractor, but need some suggestions. Right now I have an LS R3039 which is a compact, 39hp tractor. It is more than big enough for my needs. I bought it several years ago to do some work on a 100 acre hunting farm I bought. I put in a lot of ATV trails and have two small 1-acre food plots that I work. Now things are more maintenance and upkeep jobs.
I’ve been thinking of downsizing to a slightly smaller tractor, but one with a cab. I use the tractor about twice a year at my hunting property to keep the trails mowed. I use it once a year to fill the two small food plots, and I use it a lot in the winter to plow driveways in my subdivision. Really need to be able to use a 6ft grader blade, a 5 or 6ft bush hog (have a 5ft currently), and use a 6ft roto tiller (rented locally instead of purchasing for once a year). Those are main uses.
I’m not opposed to buying used, but it would have to be clean and low-hour. Looking for recommendations. Have pretty much all the major brand dealers in my area except TYM.
/ Small Cab Tractors #2
Cabs are expensive, both the integrated cab from the factory and bolt-on-cabs. Or you could go with a soft cab for a lot less cost and comfort.
What direction are you wanting to go?
/ Small Cab Tractors #3
If you can check out the Yanmar YT235C. Test
drive a lot of small tractors with cabs to see what
fits your needs and what makes you comfortable
willy
/ Small Cab Tractors #4
Kubota LX3310 is slightly less horsepower but more options for comfort and a nice factory cab.
/ Small Cab Tractors #5
I don't see a whole lot of downsizing if you need to use a 5-6' brush hog. Also, snow work is much easier with larger (heavier) machines.
I have had 2 Kubota Grand L's over the years, one open station, one cabbed. The L3410 was ok for plowing, but not comfortable to use for hours at a time. The L4060 cab tractor was a big step up in comfort and snow plowing ability.
Good luck with whatever you decide to get!
/ Small Cab Tractors #6
Cabs, both factory-installed and bolt-on, are pricey. You may also take a soft taxi for a much lower rate and more comfort.
What are your plans for the future?
If you have the opportunity, have a look at the Yanmar YT235C.
Drive a variety of compact tractors with cabs to see which one best suits your needs and provides the most comfort.
/ Small Cab Tractors #7
The add on cabs have no a/c and I don't
believe they are air tight so you can
get a lot of dust/dirt in the cab. I don't know
about heat. Maybe they don't have heat either.
willy
/ Small Cab Tractors #8
I don’t think that a cab is all that expensive, all things considered. Mine was around $5k, maybe a little more, but if I were to sell now, after four or so years, I would get much of that back.
Some people plan to keep their tractor twenty years. If the cab is amortized over that period, it’s not that much, either.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2001 International 4000 DT 466E (A60462)
2001 International...
HOMEMADE TIRE DRAG (A63291)
HOMEMADE TIRE DRAG...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
