clemsonfor
Super Member
I have a ym2000 yanmar 2wd. For those who may not know its 24 engine hp and weighs around 1700lbs no weight added (i dont have suitcase weights, wheel weights or ballest tires). I am looking to buy a disk harrow. I have found a used set with i think 16 disks in 2 gangs(4 individual axles with 4 disks per axle). The rear of the disks is just over 5 ft and is an angle iron construckion type. I looked online at lineback and looks very similar to one they have listed around 540 lbs. Would this be too much disk or to heavy to pull in my heavy clay to clay/sandy loam soils for food plots? My other thought was what if i get it and take 4 disks off if i was bogging down pulling it or if needed 4 from the front gangs and two off the back to get even less resistance, would the weight of the frame just push harder on those remaining disks that i would bog the same unless i watched my draft?
The other scenario is to buy a new 12 disk harrow that is a 4 ft leinback model that is in the 350lb range.\
I was wondering what yall think, if i can go the used route it will save me around $200 (its price is $350).
My thinking is i can always take disks off but i cant add them, easily at least,.
And if i can get the larger one i dont have to worry about leaving tire tracks if i remove inner disks.
