single acting
/ single acting #21
If you are satisfied with a SA cyl, then continue using it.
It does need some weight to make it retract.
I don't believe one can convert a SA cyl to DA.
If you keep adding valves, you will have a spaghetti mix on the area.
If you use stacked valves, you can mix DA spools with SA spools in the stacked valve arrangement.
/ single acting #22
Well that's nice, but I have done it.
It is much easier than buying a new cyl.
If you look at the piston seal on a SA cyl, it may not be intended to work optimally in both
directions, but it also might be a symmetrical seal. It does not really matter if
the retraction forces are not great, as in this application.
Of course, you can not convert a "displacement cylinder", which is single acting cyl with
the rod diameter equal to the cyl ID.
/ single acting
the tipping trailer empty is heavy enough to lower with the current SA cylinder so that is no problem :)
don't mind having the odd pipe here and there as i am used to that in any case but yes working on it could be confusing but i can live with that
when you say stacked valves do you mean like this?
i would install a 2 valve block like the above of DA valves and then a single SA valve separate for things such as the trailer and lowering and raising SA mowers
Cheers Ed
/ single acting
ah!
would indeed make things neater with only one feed and one dump line and also it would be cheaper as i wouldn't need so many hoses making up
now i just need to find one in the UK or see how much it is it import one from the US
Cheers Ed
/ single acting
/ single acting
actually scrap what i just posted above, i'm pretty sure that's still not a stacked valve
Cheers Ed
/ single acting #28
Do you absolutely need a SA valve with only one work port.
A DA valve will do the same thing after plugging one p ort.
There are plenty out there.
https://www.google.com/search?q=ces...a=X&ei=Z_NkVNOhK8eogwTgmoOwDg&ved=0CAYQ_AUoAQ
It is just too easy to convert a DA valve spool to SA by plugging one of the work ports, or running the unused workport to tank.
A monoblock valve is one piece construction.
A stacked valve is just that, spool sections stacked together with an input and output, and bolted together..
/ single acting #29
Sounds like you need a three spool DA valve and plug one work port on the third valve to make it a SA spool.
/ single acting
plugging one work port on a DA, now that sounds like an idea!
or as you say i could run it to the dump line, would just plugging it cause any extra wear to the pump?
is this all i need to plug it, obviously in the right size
Blanking Plug Hydraulic Compression Fittings Part Number - VS-M20X1.5-WD | eBay
also is the dump line under pressure, would i need a check valve on any lines T'ing into the dump line to stop other oil being dumped going up the pipe T'ing into the main dump line, if this makes sense? can do a basic diagram if it helps?
Cheers Ed
/ single acting #32
Yes, that is a stacked valve.
You can see the bolts connecting the spool sections together.
/ single acting
contacted two companies now for a quote on stacked valves with 2 DA valves and one SA with carry over (PB) port and 1/2" ports and one is going to post me a quote and i will phone one on monday when their specialist valves guy is back
Cheers Ed
/ single acting
is there really an advantage if getting a slice or stacked valve with 3 double acting ports and plugging one outlet and just getting a normal mono block 3 valve block and plugging one outlet?
basically is there any advantage of getting a stack valve over a monobody valve if they have the same specs and you are doing the same thing with them?
just getting a monobody would be a fair bit cheaper
and for a 3 point mounted forklift of a reasonable size, what would determine if i need 3/4" ports or 1/2" and how many l/minute flow rate i need?
Cheers Ed
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2006 MACK CHN613 DAYCAB (A67714)
2006 MACK CHN613...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
CAT 416B Front Loader Bucket (A68134)
CAT 416B Front...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
