Simplicity Conquest - value???
/ Simplicity Conquest - value??? #1
lnjr
Hello,
I was just wondering if someone could possibly tell me approximately what a Simplicity Conquest would be worth. The reason that I ask is because my parents have one that they no longer use (purchased new in 2004) and offered it to us. I would like to give them what it is worth --- not just take it from them.
Here is the info on the lawn tractor.
Simplicity Conquest --- 16-HP Briggs & Stratton Vanguard V-Twin engine. 44 cutting width; Hydrostatic / foot controlled automatic transmission; Free floating mower deck with full width rollers; Infinite height of cut adjustment; Quick hitch attachment removal system with mechanical spring assist attachment lift; Padded, soft grip steering wheel; Easy adjust 15 high-back seat; Cruise control; Four headlight illumination; Automatic Controlled Traction and differential lock; Heavy-duty attachment lift lever; 16 front/23 rear 4 ply tires; 2 cylinder with electronic ignition; 18 turning radius; Low effort steering. This unit has 155 hours of use on it and there is also the 42 snow/dozer blade; rear weights and carrier; mulcher/shredder kit; rear chains; cart & a spreader to go with this unit.
Any information would be Greatly Appreciated.
/ Simplicity Conquest - value??? #2
Do you know the original sales price of the tractor, attachments and accessories? That would be a good starting point...
For example, I'd guess the tractor and mowing deck cost in the $4800-5000 range, then you add the other things.
Then, factor in depreciation...
Now 5 years old, with only 155 hours (below the average of around 50 hours/year), I'd SWAG its value to be something between 1/2 and 2/3 of the original cost.
That may be a bit above market value (based on just eBay or dealer trade-in) but would likely come close to what a dealer would sell the used machine for... A key difference is you know the seller, the condition and the maintenance history.
Just some thoughts as a beginning point....
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
VOLVO A25D Cab (A68134)
VOLVO A25D Cab...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
