Simple Framing Question
/ Simple Framing Question #31
I've been thinking about a single beam. I have a couple of 4 x 4 x 8 oak posts and it's hard enough to lift those very high. I don't see being able to handle a 4 x 8 x 14 to a height of 8' without some kind of machinery. I could do it one end at a time and place scaffolding to support it. But then I'd need some kind of specialty hardware to anchor, or I'd need to notch the posts.
Plan for now is as shown. 2 x 8 headers on each side of the posts. Center post would not normally be there, but could be installed if we get a heavy snow forecast. Fill between the headers to support on top of the temporary post might be a couple of pieces of 2 x 8 or 4 x 4, whichever I have available. This way, I can use more standard brackets and timber screws or nails.
I can use my normal method of ratchet straps to lift each end of the headers into place so I can drive anchors.
I made a jib pole from an old drive line and use my loader bucket to lift up logs or beams. I have used scaffold on one end and then the other end to lift a 6x16 x16 feet long for a garage header in place. But I was only 50 at the time on that one.
Kubota B2301 (A53317)
XCMG CV83PD (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
