Siding for pole barn
/ Siding for pole barn #1
mopower440
middle tennessee
lawntractor only
well, after i get the trusses up and the metal roofing up, i will ready to side the pole building, i originally was going to use metal siding also, but am kinda thinking about wood now, not sure, just thinking, wondering if it will be ok to use wood instead of the metal since i have the girts on 2' centers..ok or no?
/ Siding for pole barn #2
What type of wood are you thinking about? Plywood sheets, board&Batten? You can just about make anything work at this point.
/ Siding for pole barn #3
I would also consider hardi plank or hardi panels. I have installed a bunch of hardi plank and like it. Never tried hardi panels, because I usually work alone and can not handle the weight of the 4 x 8 panels.
Bob
/ Siding for pole barn #4
Are the hardi planks made of cement or a composite?
PJ
/ Siding for pole barn #5
Hardi planks and sideing are made with a lite weight concrete
the stuff is pretty thin but won't check like plywood will (causing paint to pell) It takes a special primer from hardi to paint and must be put on over underlayment
If I was doing it I would ist put on OSB thick enough for 2ft centers then side with primed hardboard sideing sheets or planks-- The important thing to do is sheet it with something (ply or OSB) because it adds the needed shear strength
Also be prepared for current ply and osb prices they have trippled since the goverment bought up a bunch of it for irack, it has started to come down a little lately but prices ars still sky high /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif If you could hold off untill spring prices will go down Most OSB comes from canada and its winter there too. Home Depot or Lowes are the cheapest and quickest to adjust prices
/ Siding for pole barn #6
I'd sure think twice about putting some type of wood on. If you have the time to take care of it every few years that's fine. With the steel you put it up and for 30 years or better you don't have to touch it.
/ Siding for pole barn #7
I have cut one inch pine for board and batten siding on horse riding rinks. The largest was 50 by 100 and 12 foot high. and it cost them a bit over 2000 dollars for the wood. They treated it with a diesel fuel, roofing tar and linseed oil mix. It looks real nice like light walnut stain. Another outbuilding that I cut lumber to side was finished in fresh motor oil and it is very bright and orange yellow. It still looks good after 4 years.
If i go with wood, it would either be OSB with vinyl siding or that T111 1/2" plywood siding with paint, but im actually looking for the cheapest way, and i 'think' its a tie between metal and the T111 plywood..
/ Siding for pole barn #9
T-111 is a pain to deal with. It has to be painted or stained every couple of years. There are different qualities of T-111 also. It may appear less expensive now, by you will pay the price later in labor....
/ Siding for pole barn #10
Hardie products are a composite of cement and fiber. They are non-combustible, rot resistant, bug resistant and warrantied by Hardie for 50 years of exterior use. Most of the products come pre-primed for paint, and one of the things I like best about them is that they take paint beautifully. Here in Florida, they are considered to be an upscale improvement.
T-111 is the worst product we can use in Florida -- may do OK elsewhere. It rots in a few years. Most of the T-111 homes around here have a band of cedar about 30" from the bottom where the T-111 was replaced near the ground. I've used HardiPlanks to cover the T-111 on my commercial property and my daughter's house.
Hardi does recommend an underlayment - OSB, plywood, etc., but it can also be installed directly onto studs with a max of 24" on center spacing. It requires a weatherproof barrier like Tyvek. It's kind of brittle, so I wouldn't install it directly over studs without a backing anywhere it might get poked, like with a FEL. Any backing is better than none, so I'm thinking about putting it on over rigid foam or builder's board. You can use foam up to 1" thick.
The only real problem comes in cutting it. If you use a saw, it should be a diamond blade. It will create a LOT of dust, and the dust can eat up the bearings on a power tool. It's best to do it outdoors. If the dust gets wet, it's a bear to clean up. If you're doing a big job, consider buying a hand-held electric shear, like the one's made by Snapper. I have two Snapper shears, and they work really great - no mess, no dust, no silicosis. The only problem is they are expensive. I've seen some a little cheaper, lately, but I paid $450 each for mine at a full service lumber yard (not the cheapest way to buy, but the most convenient).
Unlike vinyl or aluminum lap siding, the stuff looks like real wood once it's installed and painted. Use HardiBoard for corner and opening trim for a truly long life installation.
The real problem for someone with girts is that they go the wrong way for Hardiplank - you need vertical studs. My own barn will be stick built with studs 16" on center. I don't like pole barns in Florida; the water table is so high I don't think the poles will last unless they are marine grade, and I don't trust them, either.
4'x8' sheets of HardiPanel are an option for girts, but I think the joints between the sheets are problematical, both for sealing and for aestehtics. They don't overlap like the T-111 does. They look great with battens to give a board and batten look.
Here's a link to the installation page for HardiPlank: Hardie installation . From there, you can navigate to other sections dealing with the panels, painting, etc.
CAT Chassis Only (A59076)
CAT Chassis Only...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
3PT 10' Rolling Cultivator (A60463)
3PT 10' Rolling...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59906)
2019 WABASH...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
