Sidehills with a cab vs without
Status
Not open for further replies.
/ Sidehills with a cab vs without #1
troverman
NH
Kubota MX6000 Cab
I am an experienced tractor operator and I use my machines to mow 3/1 slope which I mow on the sidehill and not up and down. This is a capped landfill with distinct tiers and berms so mowing up and down is simply not practical. I've been performing this job for 4 years now and not had an incident. I use a 2002 Kubota L4310 and a 2013 Kubota B2920 for mowing. Both tractors are running flail mowers (6' and 4', respectively) behind them. Both have loaded rear tires; the B-series has 2" wheel spacers on the rear.
After a few years of breathing in dust, pollen, and grass clippings I'm thinking I'd like to get a cab tractor. Specifically, a Kubota Grand L 60 series machine. The idea of filtered, cooled air is very appealing.
My question is regarding the stability difference of a tractor with a cab. I believe the old L4310 has the same size tires as the L60 series. However, I'm assuming the added weight and height of the cab would make the tractor more top-heavy and less stable on a side hill? How much of a difference would there be?
Thanks in advance.
/ Sidehills with a cab vs without #2
The 3:1 slope is aggressive. Those slopes make me nervous even without the cab.
I don't have a direct apples to apples comparison, but we use my 770 on slopes quite a bit. It has unloaded turfs with a homemade cab that is really heavy. But it has gone on its side a least once that I know of, on slopes that aren't quite as steep. Loading the turfs and wheel spacers are on the list of projects.
The cabs will add quite a bit of weight, raising the COG. I wonder if it would be offset with 2 or 3" wheel spacers? i think if you can live with a wider track, you may be OK, but would want a lot of verification here and with your dealer before purchase.
/ Sidehills with a cab vs without #3
My question is regarding the stability difference of a tractor with a cab. I'm assuming the added weight and height of the cab would make the tractor more top-heavy and less stable on a side hill? How much of a difference would there be?
Some.
Consider ordering factory radial tractor tires, which will lower tractor center of gravity slightly, are wider and used inflated at lower pressure. Radials yield better traction because with lower pressure three tread bars normally contacts the ground, not two.
Fill the tires 1/2 to 3/4 with liquid. I would fill 1/2 with premium priced, dense Rim Guard in your situation.
VIDEO: tractor radial tires - YouTube
Grand L cab with heat and AC will weigh 600 pounds.
/ Sidehills with a cab vs without #4
I'm sure others with real world experience will chime in, but from a physics perspective:
1. How much more does the cab model weigh than open station? (Lets say its 500lbs)
2. Where is center of gravity (COG) for just the cab itself ? (Guess: About 3/4 of it's height? Say 4' above operators feet?)
3. Say the COG of an open station tractor is at operator's feet too.
Using these made up numbers, it would seem the cab's additional "levering" effect is that it raises the tractors COG the same as if you've added 500 lbs 4'-6" above an open station tractor's COG. Someone may be able to calculate how much overall COG raises if base tractor is (say) 4000lbs.
Whether this higher COG is that significant depends on your tire spacing width.
/ Sidehills with a cab vs without #5
How many acres? IMO you would need to step up to a 4WD AG tractor with duels on rear and fill all the tires with fluid.
I use a 155 horse machine no spacers(those would cut turning radius), no weights just fluid tires with a landpride batwing that has aircraft tires.
Laminated wheels won't stay on the slope especially when backing up getting in corners.
I'm mowing 300 acres on a flood control structure. I can get on a slope with my set up you can barely walk up. But I'm not turning on it just backing in there and driving out.
I was mowing the other day and went on a ride for about 40 feet, I was turning down hill and the tractor wasn't in 4WD, it took off sliding towards a concrete v ditch and luckily I just was able to keep turning left and didn't jackknife the bushhog or go into the ditch.
I hope you find something and get out of the dust.
/ Sidehills with a cab vs without #6
1010
You solution seems rather extreme,
OP
Believe OP would be better off looking at a power trac. Suggest sending Moss Road a PM, seek his opinion, although they no longer offer cabs.
A 700 series Bobcat skid steer has a cab and AWS, so they turn like a tractor, no lawnscape damage. Very wide stance tires available PLUS
Very low center of gravity. 90" finish mower or a variety of rotary cut options. Nice cab, many amenities. Expensive however, about 58K ($)
They are part billygoat operating on a slope, 90+ hp, NO DPF, very powerful.
EDIT:
I added a cab to my MX, increased weight 900 pounds. I am very conscious of the change in gravity center when I operate on a grade.
/ Sidehills with a cab vs without #7
I'm guessing the cab would raise your COG a bit. I should not say this, but it seems tractors can handle a grade much steeper than what I am comfortable with. I saw a 5000 series deere mowing sideways on a ditch slope the other day that I could not believe.
This ten foot 56 HP Cushman is about the safest thing I know to cut slopes. Not so great in the water!
IT will put the Steiner with duals to shame and I can almost guarantee it would start to slide on a slope before over turning.
/ Sidehills with a cab vs without #8
Jeffy
The radial tire would NOT be a wider tire. Size, (rolling circumfrence) remains the same however w/ a metric designation. Do agree the contact footprint is increased. The psi for 3rd generation radials may be lower but 3rd gen tires are produced only for large AG tractors
Believe tire manufacturers market radials for increased traction and NOT hillside stability. Can you share literature touting radials for sloped applications? Just have NOT seen that marketing approach?
/ Sidehills with a cab vs without #9
1010
OP
EDIT:
Nope not in the least, the horse power could be less but I wouldn't go below 85 really 100. What I posted is what will get on a steep slope and cut grass safely. But if he only has a few acres then that would be different. You look at what road ROW crews use on GRASS, LMAO, I've never seen them with a freaking skid steer, LMAO!!
/ Sidehills with a cab vs without #10
1010,
Never seen a roadside mower w/ duels? Got some pics, Many of those operators have frequent underware changes. Ther primary purpose for tractors is twofold: one is visibility and the second is roadspeed so they can get back to the barn to change their shorts.
And dont laugh too hard, wouldn't want to to loose your balance. The OP is not mowing the roadside, CORRECT?
1010, Completely missed my point, Said tractors are used over skidsteers for TRAFFIC visibility. Said nothing about duels and speed. But the Current trend for roadside work is a hydo side mount flail and a rear flail. Duels DO interfer w/ that Application!!
EDIT: ROW tool my utility uses: ROW and Roadside maintenance, two very different applications, the OP does neither. The additional hydra ax head used for Utility Power Line access maintenance.
/ Sidehills with a cab vs without #11
1010,
I'll get pics tomorrow at work, duels won't hamper visibility at all, and certainly don't cause reduced speed. Like I said this setup will cut grass on slopes that you can barely walk up.
/ Sidehills with a cab vs without #12
Here in AL I have watched those ROW mowers on I22 that looked like they were at 45 degrees mowing sideways. I do know that they have tilt alarms in those cabs.
/ Sidehills with a cab vs without #13
I don't do any kind of mowing with my M6040. However, I've been on a couple steep side slopes. The feeling I get while trying to maintain contact between my butt and the seat - - Well, I don't care what anybody says - - I would not remain at that angle and mow grass, not even for God himself.
Somewhere - I saw a tractor mowing steep slopes and it had an outrigger on each side. The outrigger on the downhill side is always down - the uphill side is always up. There was some kind of big 'ol tire at the outboard end of each outrigger.
/ Sidehills with a cab vs without #14
Tractor Training Wheels!!! :D
/ Sidehills with a cab vs without #15
So a 3 to 1 is what, 25 degrees? Man that is steep I see guys doing it with heavy tractors in our area (larger ag style with outboards) wheels weighted, they are in a cab...
I like my slope tractor, but I do pine for those that have a cab. What about an Antonio Carraro?
/ Sidehills with a cab vs without #16
To the OP,
3:1 slopes are common. That's the standard ditch slope for state and federal highways. Down here in the deep south, almost every tractor mowing the highway ditches has a cab. That being said, they're almost all green, and big. (most are 6000 series, some 5000) JD's are typically much heavier than the same HP tractor of any other brand. All of that weight between the wheels helps to keep the sunny side up.
My 5085M and 5083E both have the tires set to maximum width. My pond levee is a 3:1 slope. I'm sure the tractors would be fine, but the operator is NOT! :D Just call me chicken, but I mow up and down. :eek:
Said all that to say this: I don't really think that a cab makes a huge difference in how top-heavy a machine is. According to the specs, my 5085M cab accounts for 750# on the weight of a 8000# tractor. And some of that has to do with air conditioning compressor, condenser, etc. That part of the extra weight isn't in the cab itself, but in the engine compartment, between the wheels. If you're comfortable mowing the slopes with an open station tractor, I think you'll be fine with the cab tractor.
JMHO
/ Sidehills with a cab vs without #19
Is the tractor the OP mentioned available with the two piece rims with the ag tires? That will provide the widest stance when set up for it.
I would NOT choose radials for continuous steep side hill operation, while they do provide a good increase in pulling traction they also roll considerably under side loads.
While I'm not a fan of liquid ballast in this application I would like it along with wheel weights if I was always up hill with the same side I'd put all the Bolt on weight on the high side
/ Sidehills with a cab vs without #20
There is a wheat farmer down south of me about sixty miles - just outside Endicott - that has one of those tractors that can "tilt". So while driving horizontally on a side hill - the frame and cab can be perfectly vertical. It is a big Ag tractor - think its a Versatile. Really blows your mind to see it come off flat ground - go around a hill and plow the side of the hill with the cab tilted. Wonder how they keep the disks or chisel plows from sagging down behind the tractor.
Status
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
Wolverine Quick Attach Brush Mower (A66408)
Wolverine Quick...
