Tires Sidebar to previous post on loaded tires..
   / Sidebar to previous post on loaded tires.. #1
Jibber
RD-13, Putnam County, New York
Kubota L3130HST 4WD, BX2350
OK.. I had a problem detailed in the previous post on loaded tires. In fixing the problem a quantity of Calcium Chloride solution sprayed from my loaded tires in all directions with great gusto over the rear innerds of my tractor. Once I had repaired the valves I gave the tractor an extended bath.. got soap into what areas I could working around the backhoe and sprayed a lot of water everywhere I could.
Now my brother says I probably have still left enough of a salt deposit that it will cause rust on the tractor.
I did hose everything off as well as I could.. Is this solution used in tires so strong as to leave a potentially corrosive residue on areas I was not able to actually scrub off with soap??
I'd hate my baby to get a coat of orange that it didn't come with.
Any advice? I'm thinking of using up a can of WD-40 hoping to displace any residue..
   / Sidebar to previous post on loaded tires.. #2
If there is any CaCl left on the thing, it'll show up as white residue once it dries.
If you don't see any white residue, you're fine. CaCl dissolves really well in water, so it comes off easy.
WD-40 is a water displacement (that's what the WD stands for).
If you spray the tractor with WD-40, make sure you use a LOT of soap and water to get the WD-40 off, and then grease all the zerks again.
WD-40 is not just great at water displacement, it is an excellent dust attracter.
I've punctured CaCl filled rears before and the tractor and I had a nice bath in the stuff. Just wash it off and you and the tractor are good to go.
You're right about WD-40 attracting dust.. but I guess I'd rather have dust than rust! I sprayed some areas around where the gushers hit.. now I'll let it set a day or so and then give it another bath. I didn't notice any white residue when it dried.
I figure the way they salt the roads around here.. the car gets enough of a salt water bath every day.. and it comes off. Of course.. most of the road salt used here is probably Sodium Chloride..instead of Calcium Chloride.. I have no idea what the difference is .. both are basically salt right?
I should have paid attention in chemistry class.
   / Sidebar to previous post on loaded tires.. #4
A salt is a metal combined ionically with a non-metal. Specifically, the non-metals of group 17 on the periodic table, the Halogens, are salt formers because they combine so readily with the metals. Sodium Chloride is NaCl in a 1:1 ration. Calcium is a group 2 element as opposed to sodium being in group 1. It combines with chlorine as CaCl2. Both are salts, both dissolve readily in water to make a solution which will cause oxidation or rusting of iron and most of the iron alloys commonly known as steel. So called stainless steel is actually stain resistant steel and will rust if left in a moist environment after exposure to halide salts. It just takes longer.
Sodium chloride is commonly used to remove snow and ice from roads due to it's relative abundance and low cost. It becomes essentially ineffective at less than 15F, and actually will freeze at 0. The temperature of rock salt and crushed ice is 0 F, half the basis for the Fahrenheit temperature scale. The other end started out at 100, just like the celsius scale, and was supposed to represent human body temperature, but apparently Fahrenheit had a fever that day.
Calcium chloride is also used to melt snow and ice, and is commonly sold for home use in the form of small white pellets that look a lot like mixed lead shot. It melts snow and ice when sodium chloride is no longer effective.
Both can be applied in solution from tank trucks, often as a pretreatment when freezing precipitation is expected.
CaCl2 is sometimes used in summer on dirt roads because it is hygroscopic, drawing water from the air and moistening the road, keeping the dust down.
Anything else?
   / Sidebar to previous post on loaded tires.. #5
Wow, now I know how you got your handle there!
both rust. I guess that's the key. Something I'd like to avoid in the near future with this tractor.
   / Sidebar to previous post on loaded tires.. #7
It's what I do for a living.
   / Sidebar to previous post on loaded tires.. #8
You are pedantic for a living?
Where do you get a job like that?
   / Sidebar to previous post on loaded tires.. #9
</font><font color="blue" class="small">( Blah blah blah {snip}
Anything else? )</font>
You didn't talk about electron sharing, filling valence shells, exothermic reaction due to heat of solvation, lattice energy, conjugate bases of weak acids, or the impact on the mho reading of the water as the salt goes into solution. Geez, no mention of whether the preferred reaction is to FeO or Fe2O3.
/forums/images/graemlins/grin.gif Just yank'n your chain! /forums/images/graemlins/grin.gif
jb
   / Sidebar to previous post on loaded tires.. #10
</font><font color="blue" class="small">( You are pedantic for a living? )</font>
/forums/images/graemlins/laugh.gif Not quite, but there are people I know who swing back and forth between sides of an issue on a regular basis. Them I would call pedantic, or perhaps pendulous. Maybe even politicians. /forums/images/graemlins/grin.gif
   / Sidebar to previous post on loaded tires.. #11
It is oddly ironic that you don't seem to know what pedantic means:
Definition of pedantic (adjective)
emphasizing minutiae or form in scholarship or teaching; strict; meticulous
Examples of pedantic
Professor Dateacha's lectures were so pedantic that his students sometimes had a tough time understanding the big picture.
A Pedant is a person who overrates or overuses book learning or pure technical knowledge. Such a person values simple knowledge, (in the form of often obscure facts and rules) over common sense and more general knowledge.
Example Pedant: Dateacha
   / Sidebar to previous post on loaded tires.. #12
I guess humor is the hardest thing to communicate via this medium. See, there is this thing called a pendulum that swings back and forth, so "pedantic" reminded me of pendulum. One of the ways I keep the kids focused is to constantly make stupid jokes and puns and since I'm pretty much in school mindset throughout the academic year, I just had to try to make a joke about...
Well, you get the idea. It was a lousy pun, and puns are generally lousy jokes anyways.
Anyways, do you know why teaching science is like eating lobster?
Details are de best part. /forums/images/graemlins/grin.gif Therefore, us science teachers tend to seem somewhat pedantic to other people. It drives my wife nuts sometimes, and other times she loves me more for it. /forums/images/graemlins/smile.gif
   / Sidebar to previous post on loaded tires.. #13
I can see you take your work home with you.
I have a cousin who taught 2nd grade for 25 years... Talk to her today and you'd swear you were talking to a 6 year-old.
I manage a herd of whining salespeople from all of the world and spend a big part of my time fighting with insane internal process, warring attorneys and cheapskate financial people.
I take my work home with me as well, so end up being a hardass all the time as a result.
   / Sidebar to previous post on loaded tires.. #14
Sounds like you need a pile of hickory logs and an 8 lb splitting maul. It works wonders on those days when you want to hit someone.
I used to teach in the inner city in Michigan but lived in the boonies. Some days I'd come home, pick up the Model 12 and a couple boxes of shells and go out and bust cans and clays for a while. That was pretty theraputic, too. /forums/images/graemlins/smirk.gif
   / Sidebar to previous post on loaded tires.. #15
fo' shizzle ma nizzle
10 acres cleared... ...no oil price feared.
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
Enclosed Service Truck (A55788)
Enclosed Service...
FUTURE MB27-27" HYD MIXING BUCKET (A60432)
FUTURE MB27-27"...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
