Side-hill safety
/ Side-hill safety #1
chelydra
Ditch Witch
Having finally passed the 100-hr mark on my CK20HST, I'm getting a little bolder about using the machine's power. Still tend to stay down around 2500 RPM even for heavy lifting, but have the used the full 3000 in a couple of tight spots. BTW, since the oil was pretty dark, I went to change the filter too. Turned out none of my wrenches would fit in that tight space, so I'm shopping for a new filter wrench. What do other people use?
With toothbar at last installed, I'm doing some more serious landscaping. Some of this really needs side-hill digging and smoothing with the FEL. I find that I just can't make myself do it - feels too unstable. I've done much more aggressive stuff with a Bobcat, where the low CG and stiff tires make it feel a lot safer.
When I walk some of these areas, they look almost flat - say 15 degree slope. When I estimate the position of CG relative to the wheels, it looks fine. It just *feels* very dangerous.
Is there an easy way to estimate safety margins short of chaining the roll bar to a tree with a little slack and actually tipping the tractor? Or is this one of those things where experience prevents error, but only error gives experience?
Thanks-
NBB
/ Side-hill safety #2
Can you do any of this work up and down the slope? That would be much safer. If you are not comfortable with working on a slope, then don't. Hire it out to someone who is more experienced. Nothing wrong with that. Make sure you work safe and do what you feel comfortable with. Just remember to keep the loader bucket down low to the ground while on a slope. Keep the roll bar up and keep the safety belts on and tight. Personally I would not push it past your comfort level. Sometimes you only get one chance to make a mistake on a tractor. Good luck!!
/ Side-hill safety #3
My farm is hilly with some steep hills and there are days when I just can't force myself to go up and down, other days the stars must be aligned correctly and I go over the same area without a second thought. I've talked with people who have rolled their tractors and it happens so quick that you really don't know what's going on. My friend rolled his with his two kids riding on the fenders, they jumped off but he wasn't so lucky, he did some serious time in the hospital. With experience comes confidence but I wouldn't attempt anything that makes you feel uneasy.
/ Side-hill safety #4
That pucker factor feeling is all you need. The only way to know when you're pushing it too hard is to feel it in your butt or when you fall over. It's not the actual slope of the hill but so many other things like the lifting and dropping of the loader and rolling a tire up onto a rock or down into a hole that give the tractor momentum towards tippage. If it was smooth grass that you just had to drive across then you can consider the actual angle and even use one of those tip meters. If you are working on the sideslope then all you have is your butt to tell you when you're pushing your luck and I would listen to my butt. On good days, my wife even says my butt speaks for itself and she can even hear it, it hasn't let me down yet.
It took me a long time to realize that it is nearly impossible to tip a dozer over. I still couldn't overcome the pucker factor on sideslopes with it. I never tipped though.
/ Side-hill safety #5
Highbeam, I hope you don't mind if I butt in here. /forums/images/graemlins/grin.gif I have to say I agree with you completely. I have rolled over a tractor and came within inches of rolling a dozer. I was backing down a steep grade that terminated at a stone and mortar wall and there after an 8 foot perpendicular drop. As I was inching my way down the right brake band broke. The lever came back and hit me and the front of the tractor started turning quickly to the right. I held fast with the left lever and she spun 90 degrees before stopping. That right track was dead center parallel on top of the wall. A few more inches and I am sure I would have been airborne. All this in the blink of an eye. That was some kind of pucker factor. /forums/images/graemlins/blush.gif Ok, now I will butt out. /forums/images/graemlins/grin.gif
/ Side-hill safety #6
Doesn't someone make a filter remover that fits over the end of the filter. I think it's just a friction fit and then turn sort of deal but it may help.
As someone who had a MF275 up on two wheels on a slope before it came crashing back down, right side up, let me say that if it gets you feeling uneasy, don't do it.
As someone else said, it is strange how working on slopes affect you. Some days I feel just fine about running across my slopes and the next day I feel uneasy for some reason. I also feel more comfortable if the left side of the tractor is high on the slope. It's also strange how different machines can get different reactions. I've never really felt safe on that Massey since the day I almost rolled it. My little B2400 also feels "tippy" so I never take it on slopes much over 15 degrees because that's where I start to pucker. I almost rolled it too when one of those little wheels fell into a hole. We have a M5700 that I feel pretty safe on but the ol' JD 820 makes me feel so comfortable that I probably take it places where I shouldn't. There's really no logic to it.
I think it was Bird who parked his tractor, a B2710 I think, on a 15 degree slope, got off and tried to give it a push to see how close to the tipping point it was. It was as solid as a rock, so 15 degrees is probably safe most of the time unless you start to slide, hit a hole, etc. No, usually when I get to 15 degrees, I'm starting to look for a way out of there.
/ Side-hill safety #7
Frank, I've used the B2710 on 15 degrees, but didn't like it. The day I parked it and got off to see if it would push over, I was on 18 degrees.
/ Side-hill safety #8
Bird, that was a gutseeee move! If i tried that i just know the thing would be cartwheeling down the slope while my neanderthal brain said, "Now that was smart!"
And yep, i was working up on a wheeler trail trying to get to my food plot by widening the trail so the Ck would fit. There is this one section that has a limestone outcrop that runns along one track causing the dirt on the other track to waller out. As soon as the CK was in that angled position the pucker factor started. I really tried to work thru it(don't know the angle) but finally the little voice won and i backed down the trail. Now what i need is a small dozer............sheeze this heavy equipment thing is addicting /forums/images/graemlins/smirk.gif!
RD
/ Side-hill safety #9
I have no problem getting my regular filter wrench in. Just crouch down facing the filter and slide the wrench in from the right hand side between the loader bracket. Slip the end of the banded filter wrench over it, it takes a little finesse, and crank away.
The one that's a real bear is the transmission filter underneath. First time I changed that one, I had to get my brother to help me push and twist. The filter was quite bent by the time is finally gave in.
As for the slopes, regardless of whether you're comfortable or not, GO SLOWLY. As has been alluded to, a depression hidden in the grass can get the momentum going. Have the loader up just a little too high, and moving a little too fast and that's all it takes.
Follow your butt er gut instincts and don't be worried about being afraid. That's what keeps one alive. Better to be safe and in good health than to find out if it will tip over, and since you're not really sure of the angle, you did the right thing to avoid it.
If you have a boxblade, you may be able to back up to the digging spot for leveling it out and not have the tractor sideways.
John
/ Side-hill safety #10
All this slopes and tipping talk has me butt puckered to the max! It also begs the question, how good is the ROPS and the seat belt in a roll over! Some of U guys sound like ur related to Evil Kinevil! /forums/images/graemlins/grin.gif
/ Side-hill safety #11
I have an old garden tractor which has the forward reverse lever just where the loader joystick is on my Kioti. Early on I was on a side hill with a full bucket but needed to back up a little to dump it. Hauled away on the reverse lever. When I carefully lowered the bucket, that thump and jolt putting me back on 4 wheels was a relief. Haven't even started the garden tractor since. /forums/images/graemlins/grin.gif
/ Side-hill safety
Thanks for all the useful comments. Done all I could up/down hill; some work just requires the machine to run cross-hill. I could sometimes get around this by mounting the BH bucket backwards - anyone ever try this?
Like EastTexFrank, I find that my tolerance for tippiness varies widely with time of day, tiredness, how long I've been working in that area.
I've also found that reflexes (so far) seem to work in the right direction. When lurches, awkward loads, a stone or soft spot have made the machine very light on one side, hands and feet automatically move things the right way to bring it all back in balance. Main thing is to HOLD STILL and think before doing anything sudden. Nearest tipovers have actually come from a sticky valve on the BH, which I'll ask the dealer to re-repair when I can spare the machine for a few weeks.
Like Awert, I have no idea how strong that roll bar is. Can it really hold up two tons of moving iron? Not that I want to find out!
Attached pic is where I'm working now.
-NBB
/ Side-hill safety #13
When I was a kid we tried Vermont living for a while, back in Fla. now, and I mowed with a small tractor with dual rear wheels and a sickle bar.
Well one day I was cross slope mowing with the bar on the down hill side when she started over. I tried to turn down the hill but no hope time to jump. Well I remember very well my first thought which was "jump past that sickle bar".
She rolled once bent the sickle bar and that was all. Fixed the bar by putting a block under it and jumping up and down.
I respect hills.
/ Side-hill safety #14
Don't know if you have one of those fancy seats like I have on my CK20, but if you do you may want to crank it all the way down so that you sit as far down in the tractor as possible this will acually change your center of gravity, the higher you sit the higher the CG the lower you sit the lower the CG. i find that the lower I sit the more comfortable I feel. I have a side hill that I work behind my house, makes me real nervous to cross it. I grew up on a farm in Wisconsin, always hated working side hills even in a big tractor with duals.
/ Side-hill safety #15
If it feels like it's gonna go over, turn down the slope hard and hit the gas. That should straighten things out.
John
/ Side-hill safety #16
I've gotten that tippy feeling with the bucket a bit high. I thought it would sure be nice to quickly lower that thing, it just doesn't drop that quickly though.
/ Side-hill safety #17
</font><font color="blue" class="small">( it just doesn't drop that quickly though. )</font>
Mine goes down very fast if powered down as opposed to floating it down. Has saved me from tipping a couple of times.
John
/ Side-hill safety #18
We live in hilly country. I can't image tipping a tractor unless I had a full bucket lifted high and turned the wrong way??? I think you would have to be working on some insane grades.
/ Side-hill safety #19
</font><font color="blue" class="small">( We live in hilly country. I can't image tipping a tractor unless I had a full bucket lifted high and turned the wrong way??? I think you would have to be working on some insane grades.
)</font>
Tractors tip over on flat ground, I've had one on 2 wheels on flat smooth asphalt. I've had several different brands nearly tip on uneven ground. There is a bulldozer near my house that is on its side in a field. The fact is a rigid frame tractor can tip over on flat ground without having a loader on the machine. When ground engaging implements are used (plow) and the tractor turns, if the implement snags you can be on your side before you know what happened. While using a FEL, if the load shifts in the bucket, the tractor can be thrown off balance and tip the tractor.
You may want to do a search of TBN and you will see many examples of tractors that flipped on their sides and owners who said "it happened before I realized . . . "
Somewhere here on TBN is a link to some film clips that show tip over tests. It shows tractors on very mild slopes rolling over. You might want to search for that thread.
I hate to preach, but if you really think it takes a lot to tip a tractor on its side, then you need to learn how easy it is to tip a tractor over. And hopefully you can learn that lesson without getting yourself injured. Please wear your seatbelt.
/ Side-hill safety #20
A re-enactment This is with the bucket down, as close as I can get to the actual site, the angle is close.
large capacity skid steer bucket (A56857)
large capacity...
2014 ALLMAND LIGHT TOWER (A60736)
2014 ALLMAND LIGHT...
2013 CAT 950K WHEEL LOADER (A60736)
2013 CAT 950K...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
