sicklebar mower question
   / sicklebar mower question #1
eddie48
McDonough, NY
TC45DA, TC40DA, Farmall Super A, New Idea spreader, Dolmar and Echo saws, Yanmar MIniEx, Ford 3550 backhoe, lots of junk
I have just finished restoring a 1948 Farmall Super A. An IH sicklebar mower (I don't know the model, and don't know how to tell what it is) came with it needing a lot of repair. I have it all together and it goes back and forth like it should, however it immediately plugs up when trying to cut high grass (hay). This seems to happen along the whole length of the cutter bar, not just at the end. Does anyone know how it is supposed to be "tuned up" to minimize this problem?
   / sicklebar mower question #2
Thank you, Gordon. They were helpful. Now to go straighten it out.
   / sicklebar mower question #4
make sure that at each end of the stroke of the pittman rod that it stops in the center of the guards.. at least that the way it was on a dearborne mowing machine. we called that getting it into time. if you have no adjustments on your mower you can try a new pittman rod and measure it and fit it to the mountings so that it will stop at the right place everytime in the center of the guards.
I'll check that, too. Thanks
   / sicklebar mower question #6
I did not check out the videos, but.
The knives have to be sharp and the ledger plates on the guards have to be sharp, with no gap between the knives and the guard shearing surfaces.
The newer serrated knives and guards will work much better then the old smooth edged ones.
   / sicklebar mower question #7
Blade hold down clamps have shims that can be removed to compensate for wear. We would douse the blades with used motor oil at the first and end of cutting season.
Flameshield Safety Oil Tank (A59814)
Flameshield Safety...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
26120 (A56859)
26120 (A56859)
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
