Sickle mower
   / Sickle mower #1
Bquick
Shelton Ne
John Deere Model A
Does any one know if JD ever made a sickle mower that works on side hills?
   / Sickle mower #2
You mean where the sickle is at a different angle than the mower frame? Almost all mowers allow for some slight variation above or below a true flat angle.
If you are looking for a mower that the cutter bar will operate regardless of angle, then you need to get into one without a pitman stick. There may be others, but the number 10 belly mount mower is the first JD one to support this that I know of.
   / Sickle mower #3
Model 50, 350 or 450
   / Sickle mower
Ken
Does the John Deere 350 sickle mower mount on a John Deere A Or is this meant for more of a 4010
   / Sickle mower #6
Ken
The JD 350 came with 3 point hitch and works on all tractors with that setup. The JD 450 is the same mower platform on hydraulic wheel carrier. The 450 is good if you don't have 3 point on your tractor. Ken Sweet
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
