Sickle mower
   / Sickle mower #1
Bquick
Shelton Ne
John Deere Model A
Does any one know if JD ever made a sickle mower that works on side hills?
   / Sickle mower #2
You mean where the sickle is at a different angle than the mower frame? Almost all mowers allow for some slight variation above or below a true flat angle.
If you are looking for a mower that the cutter bar will operate regardless of angle, then you need to get into one without a pitman stick. There may be others, but the number 10 belly mount mower is the first JD one to support this that I know of.
   / Sickle mower #3
Model 50, 350 or 450
   / Sickle mower
Ken
Does the John Deere 350 sickle mower mount on a John Deere A Or is this meant for more of a 4010
   / Sickle mower #6
Ken
The JD 350 came with 3 point hitch and works on all tractors with that setup. The JD 450 is the same mower platform on hydraulic wheel carrier. The 450 is good if you don't have 3 point on your tractor. Ken Sweet
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
71053 (A49346)
71053 (A49346)
