Sickle mower
   / Sickle mower #1
Bquick
Shelton Ne
John Deere Model A
Does any one know if JD ever made a sickle mower that works on side hills?
   / Sickle mower #2
You mean where the sickle is at a different angle than the mower frame? Almost all mowers allow for some slight variation above or below a true flat angle.
If you are looking for a mower that the cutter bar will operate regardless of angle, then you need to get into one without a pitman stick. There may be others, but the number 10 belly mount mower is the first JD one to support this that I know of.
   / Sickle mower #3
Model 50, 350 or 450
   / Sickle mower
Ken
Does the John Deere 350 sickle mower mount on a John Deere A Or is this meant for more of a 4010
   / Sickle mower #6
Ken
The JD 350 came with 3 point hitch and works on all tractors with that setup. The JD 450 is the same mower platform on hydraulic wheel carrier. The 450 is good if you don't have 3 point on your tractor. Ken Sweet
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
Toro Workman Cart (A50322)
Toro Workman Cart...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
