Shuttle Shift?
/ Shuttle Shift? #1
jbunkley
North Florida
2006 Branson 3510i
The shuttle shift on my brand new 3510i (3 hrs) is very very stiff. I have
never used a shuttle shift before & didn't know if this is common or is there a
break-in period. :confused:
Thanks
/ Shuttle Shift? #2
I think this may be a common problem as quite a few posts here about stiff shuttle, mine was stiff for maybe the first couple of hours usage, I have read others say give it the first 50 hours to loosen up. One poster had a good idea to give it a quick jerk, so instead of tugging on the lever give it a quick jerk, and remember, its just like a car with "3 on the tree" you need to also pull up on the lever during the process. The quick jerk method is what I used and it freed up quickly. Hope this helps. H.
/ Shuttle Shift? #3
56 hours on my 3510 and I still have slam it into gear. I probably miss about 1 in 20 times. It feels like there is a stop that keeps it from going all the way in if I shift easy. I'm so use to it I don't even think about it now.
/ Shuttle Shift?
Thanks for the replys...kinda what I figured.
/ Shuttle Shift? #5
It does take a sharp pull to get a positive engagement. You can try spraying some lube like twister or WD40 at the area at the base of the steering column and work it in. It should help if it is stiff
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2000 Toyota 4Runner SUV (A66738)
2000 Toyota...
2 PALLETS OF SNOW CHAINS (A66091)
2 PALLETS OF SNOW...
2016 CHEVROLET IMPALA (A66091)
2016 CHEVROLET...
