Shuttle Shift?
/ Shuttle Shift? #1
jbunkley
North Florida
2006 Branson 3510i
The shuttle shift on my brand new 3510i (3 hrs) is very very stiff. I have
never used a shuttle shift before & didn't know if this is common or is there a
break-in period. :confused:
/ Shuttle Shift? #2
I think this may be a common problem as quite a few posts here about stiff shuttle, mine was stiff for maybe the first couple of hours usage, I have read others say give it the first 50 hours to loosen up. One poster had a good idea to give it a quick jerk, so instead of tugging on the lever give it a quick jerk, and remember, its just like a car with "3 on the tree" you need to also pull up on the lever during the process. The quick jerk method is what I used and it freed up quickly. Hope this helps. H.
/ Shuttle Shift? #3
56 hours on my 3510 and I still have slam it into gear. I probably miss about 1 in 20 times. It feels like there is a stop that keeps it from going all the way in if I shift easy. I'm so use to it I don't even think about it now.
/ Shuttle Shift?
Thanks for the replys...kinda what I figured.
/ Shuttle Shift? #5
It does take a sharp pull to get a positive engagement. You can try spraying some lube like twister or WD40 at the area at the base of the steering column and work it in. It should help if it is stiff
2020 PETERBILT PB337 SERVICE TRUCK (A59823)
2020 PETERBILT...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
