Shutter plate
/ Shutter plate #1
MapleLeafFarmer
Platinum Member
Canada
lots including Kubota B's, L's, cat, etc.. over many years
on my 2012 Kubota B2620 under the battery is a "shutter plate".
This is what the Kubota manual calls it.
Any idea what its for or what it is supposed to do?
Thanks
/ Shutter plate
I am thinking it has something to do with keeping exhaust heat away from bottom of battery. (rad overflow protects the side)
/ Shutter plate #4
I think it is to direct the airflow through the rad screen so it doesn't suck unfiltered air into the radiator.
/ Shutter plate #5
When cleaning area in front of radiator( ie..hosing off), pull the shutter forward and it allows debri to fall clear.
/ Shutter plate #6
boakley - The shutter plate on my 2003 B7500 collects a lot of debris that would otherwise find its way to the radiator fins. I pull the shutter plate and remove the debris when I clean the front grille, radiator screen and radiator fins. The debris collects on the underside of the shutter plate.
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2003 CATERPILLAR 252 SKID STEER (A65053)
2003 CATERPILLAR...
PALLET OF WHEEL SPACERS & WEIGHTS (A64278)
PALLET OF WHEEL...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A67148)
2015 FREIGHTLINER...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
