Shutter plate
/ Shutter plate #1
MapleLeafFarmer
Canada
lots including Kubota B's, L's, cat, etc.. over many years
on my 2012 Kubota B2620 under the battery is a "shutter plate".
This is what the Kubota manual calls it.
Any idea what its for or what it is supposed to do?
Thanks
/ Shutter plate
I am thinking it has something to do with keeping exhaust heat away from bottom of battery. (rad overflow protects the side)
/ Shutter plate #4
I think it is to direct the airflow through the rad screen so it doesn't suck unfiltered air into the radiator.
/ Shutter plate #5
When cleaning area in front of radiator( ie..hosing off), pull the shutter forward and it allows debri to fall clear.
/ Shutter plate #6
boakley - The shutter plate on my 2003 B7500 collects a lot of debris that would otherwise find its way to the radiator fins. I pull the shutter plate and remove the debris when I clean the front grille, radiator screen and radiator fins. The debris collects on the underside of the shutter plate.
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2023 Case TV380 (A62177)
2023 Case TV380...
2012 CHEVROLET SILVERADO 3500HD (A63569)
2012 CHEVROLET...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
