shut off solenoid
/ shut off solenoid #1
aquabar
2007 New Holland TN75DA
I have a New Holland TN75DA tractor, it will not shut off when I turn off the key. I have to put in gear and let it die. where is the fuel cutoff solenoid or wires?
/ shut off solenoid #2
It's on the end of the fuel injection pump. Your problem could be a bad ground.
/ shut off solenoid #3
It may look similar to this. (Not sure if the TN75 is the same as your TN75DA)
Mike
/ shut off solenoid #4
Check fuses, my MF1250 would sometimes do the same. Was always the fuse.
/ shut off solenoid #5
I know nothing much about your NH but my Mahindra has an emergency manual fuel shut-off at the bottom of the steering column - works like a parking brake release, cable operated to mechanically override the electric solenoid. Sometimes when it's been worked hard in hot weather I have to use it to shut her down fully where the solenoid won't quite do it for some reason.
/ shut off solenoid
I found the solenoid and I pulled the wire off and it would shut off, so the solenoid is good. I can't find another wire in the area. The problem was intermittent but now is full time. It sounds like a bad ground that has come completely off now but I don't know where to look for the bad ground.
any ideas?
/ shut off solenoid #7
um follow the wire?
/ shut off solenoid #9
It seems a number of people are confused about grounding problems. It's a single wire circuit right? That means it's self grounding, so why search for another one? If you remove the wire (removing 12v source) the engine stops. How is that a grounding problem?
What you have is a problem in the power circuit to the pump. Could be any number of things, a shorted diode, stuck relay, who knows? Could be fun to trace without the proper wiring diagram for that particular tractor. There is no "one size fits all" diagram because of all the model variations. Has anyone been working on the wiring or electrical system lately?
One more thought. You might remove the four screws and lift the instrument cluster out. Look for signs of a rodent domicile,
/ shut off solenoid #10
I suggested to check any relays as this happened to me on a small engine this month. Fuel solenoid worked great when bench tested. The issue was with a $16 relay that controlled the solenoid.
/ shut off solenoid #11
All the wiring on my Century tractor started giving me issues. I got so frustrated that I removed all of it and then just wired what I absolutely needed for it to run.
Instead of using a wire to power the solenoid to pull the lever on the injector pump to stop the engine, I attached a manual choke cable to it. I pull it towards me to start the tractor, and push it in to turn it off. It's 100% full proof to work every time!!!
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
