3-Point Hitch Shudder on descent
/ Shudder on descent #1
kpmcneil
Cape Breton, Nova Scotia
Fordson Super Major 5000 Diesel, MF 50 backhoe
1963 fordson super major 5000. When I lower an implement with 3ph there is a distinct and pronounced shudder as it descends. Not an issue when raising, but I can't seem to set a constant draft angle, implement will raise at times without moving control. What part of the hydraulic guts should I look at first.
/ Shudder on descent #2
consider making a set of check-chains to limit cutting height. I did that with my old H.Ferguson 30, it would not maintain set height either. I used an extra long top link pin in the tractor and made ends for the check-chains with a 3/4" hole, then ran the chains down to each lower pin on the mower; an A-type configuration. It took a few tries to find the correct chain length.
EDIT/UPDATE: I just discovered this is available as a kit.
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
PALLET OF HOSE REELS (A68842)
PALLET OF HOSE...
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
