Show Us Your Favorite Vises
/ Show Us Your Favorite Vises #21
What? No one has a vice on the back of their truck?
Here痴 my post vise using a 12 ductile iron water pipe filled with concrete.
DANG,, I have that same piece of 12" ductile iron pipe,, filled with concrete,,
except, mine is a lawn roller,,, :confused2:
/ Show Us Your Favorite Vises #24
That looks more like a driveway roller to me... which seems to be doing a pretty good job for that purpose.
It was originally built for the vole runs that pop up each winter, so I call it a lawn roller,,
That roller has rolled literally dozens of acres of new landscaping,,
either my SIL or me tear up dirt somewhere each year,,
But, yea, it does driveways nicely,,, also,,,
/ Show Us Your Favorite Vises #26
I love these vice threads... I have four vises, and a 20T HF press and yes it is on wheels. As are my two bigger vises.
/ Show Us Your Favorite Vises #27
Every time I see one of these old vices, I am overwhelmed with flashbacks. A bit of a diversion, but I thought I'd share. When I was growing up, and until I got into my late teens and discovered girls, I spent every summer with my Grand dad and my Dad's two younger brothers. I loved Grampa and everything he did. It so happened that he had one of these old, gigantic vices in his garage, and I like to play in the garage and with the old vice.
It goes without saying, that it had the same kind of handle that is pictured in most of these photos; the kind that slides up and down, so the handle is always pointing down. Like I said, this was a huge vice, and the handle was big, long and heavy. I liked to piddle with it, lift it and drop it and listen to it clank. One day I got a little careless, and I let it drop while I still had it between my fingers. When the handle reached the bottom, there were my fingers. It mashed both my finger and my thumb; and I had a blood blister on each of them that was as wide as my finger and my thumb.
I was only maybe 5 or 6 years old, and I thought I was crippled for life. If anything, it was painful, and I never forgot that experience...and I never look at one of those old vices today without thinking about that incident over 70 years ago.
/ Show Us Your Favorite Vises #28
Try not to GET YOUR NUTS IN A VISE.
/ Show Us Your Favorite Vises #29
This is my favorite, but also the least used. It's just too big but that's why it's my fav.
It's a Parker 978. I think I'm going to mount it to the side and lower on this 30" steel I beam "table" I made up to be an "outside" bench.
Don't worry, I oil it every year at least, and it remains in operating condition although it's just sitting there. It's jaws are at almost 5' the way it sits as shown. My plan (one day) is to mount it so that the beam of the front jaw is about level with the bench top but I'm open to ideas.
/ Show Us Your Favorite Vises #30
My favorite vises are on the other end of the scale. These old Craftsman drill press vises. I use them often.
/ Show Us Your Favorite Vises #35
I’ve had one of those Craftsman dp vises forever! The oilcan and chip tray is what caught my eye.
I have had this vise for 25 years,, sitting on the shelf,,
other than threading pipe,, is there any worldly use for this thing?? :confused2:
/ Show Us Your Favorite Vises #37
Mine isn’t a chain vise but I use it frequently for pipe work. Not so much threading but for assembly or taking apart.
Your chain type pipe vise is handy for holding irregular shaped items.
No one has resurrected a 4 year old thread in a couple hours,, so I figured I would put one on life support,,
I never had much in the way of a typical "bench" vise,, but, I have some vises that are "doozies",,
The one in these pics was a real lifesaver on my CNC torch,,
Rather than cut sheet material, I CNC torch cut bar stock, typically lengths cut in half, so about 10 feet to 12 feet long was the raw material.
When I wanted to cut sheet steel, I had the supplier cut the sheet to the width of the part, and I fed that just like bar stock, typically 10 to 12 feet long.
The width was identical, or close to what the dimensions of the part was to be,,
Anything from 2" wide to 15" wide,, I needed a way to hold the material.
This vise did the trick. with a capacity of 0 to 16",, with 10" wide jaws, and the movable jaw is fast acting,, the handle was gone, I made one out of an import wrench.
(That wrench is "over-size", it will slide from nut to nut, but, still turn the nut without slipping)
The bar stock rolled on the rollers, . Repeatability was necessary because most parts used the mill edge as integral to the torch cut part.
This vise held the material the same, part after part, as long as you wanted to keep feeding the bars.
Some days I would cut several tons of parts. Slide a bar off the forks of the forklift, hit the stop , cut the part.
Usually the biggest effort was to catch the cut part.
Actually, I have a second one of these vises,, I did not know if the machine was gonna need two vises, so I bought both of the used vises.
/ Show Us Your Favorite Vises #39
I bought this one 40 to 50 years ago used. Before I has a press, I would put a piece of pipe on the handle and crank away. Hasn’t failed yet.
/ Show Us Your Favorite Vises #40
I have one just like it. I've had it so long...over 50 years... I don't even remember where I got it.
