Backhoe Should I ad a Thumb to my backhoe purchase today?
   / Should I ad a Thumb to my backhoe purchase today? #31
I have used my hoe for probably twenty years with no shortage of boulders around here. I'm the first one to get something if I figure it will be easier or just more fun, but just don't see it. I hardly think all my hoe work was done at 50% efficiency. Usually, boulders go right back in the hole or trench once a covering of nice fill has been introduced. I could see, if I had to pick a bunch of boulders out of a pile and put them in a loader bucket or trailer, but that's kind of rare.
   / Should I ad a Thumb to my backhoe purchase today? #32
How do you figure that? I dig holes and trenches mostly. I can pick out large rocks without a thumb. Please explain your math.
Without a thumb:
On a flat surface you can pick rocks up after you first chase them around for a while.
You can place a rock, but first you must drop it, and then try to push it into place.
If a rock falls on the back side of a pile you need to reposition the machine to try to pick up again.
You can dig stumps, but depending on size they can often be just pulled with a thumb.
You cannot drag a beam, log, or pole from it's end.
My L48 thumb is quite robust.
I love it, and will likely find new uses for it.
   / Should I ad a Thumb to my backhoe purchase today? #33
Yeah, I think if I had to do all that individual rock moving, it would be a benefit. But mostly they are just part and parcel of removed spoil, all handled at the same time.
If I had anything I wished for, it would be a rotating logging style grapple. For the loader, not hoe.
   / Should I ad a Thumb to my backhoe purchase today? #34
I try not to put bigger rocks back in the ditch. I’ve had to fix too many lines busted by them. If it’s a deep enough trench I’ll put a foot of dirt in and then set the rocks back. The thumb makes it much easier to throw them aside to deal with later. But I use the thumb for much more than moving rocks.
   / Should I ad a Thumb to my backhoe purchase today? #35
Typical little digging job around here last summer, burying a couple of pets. Put limestone sreenings back in first and then all that junk went back in. Don't remember any really large stones.
   / Should I ad a Thumb to my backhoe purchase today? #36
What’s that Kubota hoe? I don’t recall ever seeing one that big.
   / Should I ad a Thumb to my backhoe purchase today? #37
Yeah, a little too big. Made by Bradco. The R510 was supposed to have a smaller fold-in type hoe generally, but a city decided to order the larger hoe for a cemetary. They loaded the front wheels right to the top to try and offset the weight!
Hoe has AUX hydraulics. Painted color of city equipment. Shame!
   / Should I ad a Thumb to my backhoe purchase today? #38
What’s it mounted on?
   / Should I ad a Thumb to my backhoe purchase today? #39
It would have been sweet if the hoe went up higher against the cab. It was a bit of a rube-goldberg! It's also nothing close in size to a "real" construction TLB. Case 580 or similar.
   / Should I ad a Thumb to my backhoe purchase today? #40
What purpose other than to pick up occasional odd debris does a thumb provide on a backhoe? Also, would a pneumatic be necessary or will a mechanical one suffice? Does one foot digging depth and 130# difference in the digging force make a real difference? Just want to know before the purchase today. I have my thoughts but wanted to know what other "users" think.
Thanks for replying.
I installed a thumb on mine. It's handy for stuff like picking up big tree limbs which then I can position over a cart to saw up and haul away with my garden tractor. I find a bunch of other uses for it, and it's not a very expensive addon, so all good. Yeh, if you got a backhoe, why not? When not using it, it folds up out of the way.
As far as getting a powered thumb, I don't see much point. If I needed that option, I'd sooner get a grapple on the loader.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2005 Peterbilt 387 with Wet Kit (A55314)
2005 Peterbilt 387...
