Shop light advice?
/ Shop light advice? #61
texasjohn said:
hmm.... I guess I didn't find the good deal on the PAR 38 LED bulbs....
Place I looked has them for $60 each and they put out 200 lumens... don't think that will do what I need... too much money, too little light.
You can look on ebay or direct thru LEDwholesalers.com.
LED Wholesalers (Powered by CubeCart)
The lumens are lower, thus the gross of bulbs!
Steve
/ Shop light advice? #62
For my new shop, I ended up purchasing Lithonia I-Beam series T5HO florescent lights. They were expensive at $160 per fixture, but that does include bulbs. I have 15 of these things to hang, so you can figure the amount of money I spent. Ouch! All but two of them are the four bulb fixtures. In my welding room where I want more light for set up, etc, I’m using two six bulb fixtures that were just under $200.
For those who aren’t familiar with T5HO bulbs, they are fairly new. The bulbs are 5/8” in diameter and typically 4’ long. A four bulb fixture only draws 230 Watts but each bulb puts out 5000 lumens. A four bulb fixture is designed to replace a standard 400 Watt Metal Halide fixture. The key is they are the only florescent lights that are bright enough to use in a high-bay application.
The reason I’m using these lights is they are instant on where as metal halide take a few minutes to come on, have extended temperature range ballast, are wet location rated (so I can put them under my shop awning) and are the most economical fixtures available.
It was a lot of money to spend, but this is the last shop I’ll ever build. I’ll post some pictures in the coming weeks when I get all of them hung.
/ Shop light advice? #63
Correction on the pricing:
4 bulb fixture including bulbs - $143
6 bulb fixture including bulbs - $178
Still ouches a little though...
John Deere 5420 Tractor (A65579)
John Deere 5420...
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A65643)
2004 FORD F-350...
New/Unused Wolverine Quick Attach Hydraulic Concrete Chute (A65583)
New/Unused...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
