Shop Ideas
   / Shop Ideas #1
John Chappelear
I'm planning on building the ultimate shop for doing projects now that the weather is getting better here in the desert. I would like to get some ideas for
work tables, overhead hoists and vice stands. If anyone could share a picture of something that works well for them, it will give me an idea of what to build. I've been collecting metal and parts for years now so I have a lot of building materials to work with.
Thanks,
Chappy
   / Shop Ideas #2
My best advise is, whatever size you want, double it and you may be happy, take a look at my 50 X 50 3 story in my gallery thats too small :D
and do lots of planning before it goes up and do it right once and not twice half way
best of luck and welcome to the forum
Jim
   / Shop Ideas #3
Code:
ultimate shop
That may be a near impossible challenge. Why not just build the shop you think will serve your needs and be prepared for ongoing modification and expansion.:D
   / Shop Ideas #4
There are lots of good Garage/Shop pictures and advice to be found on the The Garage Journal Board. You might start by looking at the gallery forum found there.
   / Shop Ideas #5
Couple things... Plan on over insulating walls and ceiling. Don't get cheap with elect. outlets and lighting. More storage cabinet and work bench space than you think you will ever need. Anything that is not a dedicated tool can be put on wheels (saws, saw tables, welding table, etc.).
   / Shop Ideas
Now that's what I'm talking about. The overhead crane is something I had planned and those pictures really helped. Does anyone have an example of a work table, vice stand, cutoff saw stand that hinges or moves out of the way when not being used? I had thought of using a receiver tube (tow hitch for pickup) system welded to my posts, but would like to get a few ideas before I do that.
Thanks for the advice,
Chappy
   / Shop Ideas #8
Chappy, I didn't have an overhead hoist or a separate vise stand, but I made my workbenches that I liked better than any I've seen, but of course there may certainly be better ones, depending on your use. I used landscape timbers for the legs, 2 x 4 framing, and 3/4" particle board for the top and lower shelf. They were all assembled with 3" wood screws countersunk (drilled pilot holes first). Then I put cardboard on the top to protect the wood from oils. You can see my bench grinder and 3 ton arbor press on the workbench on the right, but my 4" vise on the left end of the left bench isn't shown in that picture. And of course, I liked having most of my tools on the peg board instead of in tool boxes.
   / Shop Ideas #9
John, could you tell us a little more info of what equipment/cars/trucks/farm machinery,etc that you plan to work on.
Couple of items, I feel are a must: big, solid stationary vise ($1000 Wilton machinist vise 8"-10"opening=wish list), a portable vise(5-6") on a moveable table or 3 legged stand. Currently, I have two portable vises; one stand is regular height, and the other is short. The short stand/vise is used about 25-30% of the time.{If I didn't have it, I would have to stand on a stepstool at the regular vise for some projects.} A portable table is usually nice, because you can set it really close to your project. Heck, I took an old barbecue grill w/wheels and removed the grill and put on some plywood on the frame and my Dad uses it on the farm.​
On the overhead hoist subject: I liked the electric chain style where the extra chain is held in a bucket overhead up by the motor. My old shop had a 3 ton like this and I prefer it to a cable hoist. If you are going to work underneath vehicles, I have heard of shops with lighting countersunk into the floor that shines upward (another wish list item). If you work on Big Iron, you may want to countersink big floor tiedowns into the rebar and concrete. This allows one to chain equipment to the floor and use hydraulic jacks to press upward to bend metal back into position.
Exhaust fan in your welding area. I like 6" or 8" bench grinders on portable stands, too. You can grind or "wire wheel" an ackward-shaped part that you wouldn't be able to manuver around a stationary unit on a bench.Have a safety shield/helmet right beside that wire wheel, too. At my Dad's farm, we use a buffer/grinder for the wire-wheel. Remove the buffer on its extended shaft and put on a 6" wire wheel. The entire wheel is open and it helps to clean rust/paint off those ackward-shaped parts.​
   / Shop Ideas #10
Way too many ideas, to come up with right now.
Add in lots of electrical outlets, I put mint in at 48" high.
Have your 220 outlets figured out, welder, plasma cutter, air compressor, truck lift, etc.
Reinforce concrete for truck lift.
If you will br in the shop every day strongly consider in floor radiant heat.
Big RV doors.
Desert? wire in for fans, and have windows up high for ventilation but does not allow a thief in.
A Bathroom, toilet, shower the works.
steve
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A51572)
1999 Volvo VN...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
