Shipping container for tractor storage
   / Shipping container for tractor storage #61
We have about 20 containers between properties. Different sizes.
The biggest threat to our containers usefulness is the floor steel cross members rusting out.
This usually happens when set directly on mother earth.
Those w/ air circulation underneath holdup pretty well.
Rust control early on pays off.
Our refrigeration units are made mostly of AL & SS.
It should be noted, I'm speaking about the FL area.
They can run from free to 4K after set up. Location is important. The delivery can cost more than the container.
Keep in mind these containers have traveled the world & cargo, its anybody's guess. If you are going to be spending a lot of time inside, you might want to clean the surfaces.
They will stack well if you have the corner ratchets locks.
Most of the 20 ft units are useless for general shipping & are now cheap. They are to small & the standard has changed for overseas shipping.
The 40 ft are in need of special transport so will cost a bit more to get to your set up area.
Get a 60 ft & you have your own bowling alley. These are seemingly endless when walking to the other end w/o a flash light.
Security is high when an over shield is in place as seen in the above unit.
That is very clean looking.
   / Shipping container for tractor storage #62
These are two 20 ft refrigeration units.
The roof is an old metal 20 ft wide roll up door.
Used treated 2X6s as cross members. Screwed down w/ SS fasteners.
Made ''J'' hooks to help hold roof to top container corners.
Note air space under container.
Set on RR ties.
   / Shipping container for tractor storage #63
I called it a "single use" meaning it was used one time, then sold....your "1 tripper", same difference. And yes, they do cost more than one that has been around the world many times. This one has doors at both ends which is great because we all know that whatever it is you want to get out of the container, it is always going to be at the far end. ;)
I decided to use it to store my Polaris 4x4 and some other things which had been in the garage prior to my getting the MF. The AC power in the garage, to run the tractor's block heater in the winter, was the decision maker as to what was getting stored where. Once I have about 8" of snow on the ground, the Polaris is put away for the winter....and the storage container sits until spring.
   / Shipping container for tractor storage #65
(Sorry to necro an old thread)
I'm preparing a site for a container. I see posts stating that you should put the container on railroad ties, and some mentioning PT wood. However, PT wood in metal contact will likely increase rust...
So, questions:
- Will a container last well if you put it on a level bed of large gravel?
- If it's really best to put it on RR ties, how much of a gap should be beneath the container? I'd like to limit the ability for critters to live under it..
- How many ties would be good to use for a 40' container?
- I'm unfamiliar with the top of the container - if it's level, will water stand on it and rust it out?
- Should there be any tilt to the container - I understand that side-to-side can cause difficulty with door closing, but if there's a bit of front to back tilt for drainage, will that stress it at all?
Thanks!
   / Shipping container for tractor storage #66
We use a lot of containers but rust is a factor here.
Rain is a constant. We lean all to one side to reduce puddles on top.
We also clean the tops & paint the topsides for another step of protection.
Never had a door stick from the listing to one side.
Cinder blocks for the under side to keep down the the under rust. Air movement helps to ****** rust.
As far as critters are concerned moth balls are used inside & under.
Our refer containers are mostly stainless steel & aluminum & are near air sight.
They are a bit shorter inside due to the o/s compressor & control box etc.
No wood floors so we fitted plywood to make them easier to slide items about.
Everything is well above grade & at least 6 inches.
   / Shipping container for tractor storage #67
So, questions:
Thanks!
You can put them on gravel but that's a lot of prep and expense. Will settle some, so would have to be leveled out again after ~6 months or so if you want it level.
The reason for RR ties, blocks, lumber, etc is to get a little airflow under it and prevent moisture from the ground coming up thru the floor. If you were to put it directly on the ground or your gravel bed held water, you might be fighting condensation issues inside of it forever. But a lot of people do just put them directly on the ground.
You only need support at the corners. They're designed to put all their weight on the four corners. More won't hurt anything, but that's all you need.
Yes, you want a slight slope from back to front unless yours has doors at each end and you will use both. If you have the doors open and catch a heavy rain, you want any water to want to find its way out of the front doors, not collect and pool inside.
The top is pretty much like the sides. Many have depressions from handling - a corner of another container hit the roof of yours somewhere making a depression/dent/divot. Places like that will collect water. If no damaged areas like that on top, it will shed water. In general you want them pretty level left-right. Too far out of level and doors can become difficult to swing. I have mine very slightly out of level to make water run to one side - i put a gutter on it and collect rainwater. Otherwise, it won't really collect water on the roof so you don't have to worry about that.
Mine is dark red/rust color. I painted the top a real light loam green color on mine. Thought that might help make it a bit cooler inside, but really just wanted to help with rust prevention and make it blend in a little better.
I had no luck with cinder blocks or solid concrete cap blocks for supporting mine. They all cracked and failed quickly. Small pieces of PT 2x8 stacked worked well for me and adjusting a corner 1.5" at a time makes it easy to get whatever type of level/angle you want.
   / Shipping container for tractor storage #68
So, questions:
- Will a container last well if you put it on a level bed of large gravel? I would go to that expense unless the gravel is inexpensive. I would use solid cinder blocks, like mobile home style.. You only need to support the 4 corners...
- If it's really best to put it on RR ties, how much of a gap should be beneath the container? I'd like to limit the ability for critters to live under it.. A gap is good to keep air moving to keep the wood and metal dry... But I understand the critter problem...
Yes but long time..
No tilt.. Doors will be effected..
Thanks!
see above for answers
   / Shipping container for tractor storage #69
I put mine on a bed of large gravel. 2" to 4" size gravel. I put the bed of gravel on top of the ground in an area where there is good drainage, so I never see water around the gravel.
   / Shipping container for tractor storage #70
If anyone elects the RR ties.....try to use new timber. There is more cost to this but they could out last some of us reading this now.
As for the critter & the needed air circulation, consider the 1/2 '' galvanized screen for your vent ports.
With the ties in place roll the screen over the top edge, down the outer face & tuck it under the bottom.
Use fence staples or something that is at least rust resistance.
Our cinder blocks are poured full of concrete when one shows signs of cracking we use the LS to lift a corner & replace w/ our new found used H Beam drops from a fab shop.
This is something some of you may want to consider too.
You can weld a couple together make a strong corner.
Depending on the use & traffic in & out the under supports may need some consideration.
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2014 FREIGHTLINER...
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
