Shifting into Low Range
/ Shifting into Low Range #1
helobubba
I have a 3054 and often have difficulty putting the tractor in low range. I never have a problem switching into high range.
When switching ranges, I have the tractor out of gear, on level ground, and in neutral on the shuyttle shift. Any suggestions other than to call the dealer?.
/ Shifting into Low Range #2
What I do-
I leave tractor in gear on the main transmission, tractor stopped, shuttle in safe direction and clutch pushed in. I then barely feather the clutch as I shift. Works every time, no grinding. The shift between hi-lo range is not synchro and the gears need help lining up. An old 4-wheel habit.
Miklos
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
New - Front mount rototiller
New - Front mount...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2026 NORSTAR IRONBULL T/A 25FT GOOSENECK TRAILER (A59912)
2026 NORSTAR...
LOOK! (A63109)
LOOK! (A63109)
