SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,632
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
You are correct as to metal strength according to about every chart I can find. Ive yet to see a composite side by side comparison with discussion. McMaster Carr has a chart showing comparability in metal strength between grades. 5 = M8.8, 8 = 10.9, 9 = 12.9.Well - I thought ASTM grade10.9 was equal to SAE grade 8. Looked at my torque tables and now I'm not so sure. Have to see if there is a cross-reference table somewhere.
For comparing torque on similar sized bolts you must consider the root area. This will vary with both the bolt diameter and its thread pitch(which affects root area, and the mechanical advantage of the helix). A small difference in root factored against difference in pitch will require some orderly thinking to judge whether the torque figures indeed make sense.
