shear pin breakage
/ shear pin breakage #1
Toby873
myakka city, Florida
Branson 4720i
Howse 6' cutter behind a Branson 4720. Broke my first shear pin due to starting the pto way too fast, second pin broke for unknown reason, now I have just sheared my third pin cutting grass, my pto is at proper speed, I am going at a good rate of speed, and I was CUTTING GRASS......I cant stand this. Any help?
/ shear pin breakage #5
Unless you are hitting something be it the ground, rocks, wood. This would not seem normal, are you using the proper size shear pin? I do not know Branson tractors but I asssume a 4720 is 47 HP? That would not seem to be way over powered for a 6 foot brush hog.
What rating of bolt is it?
Are the blades able to move freely, so that when you hit the thick patch of grass the blade can move.
Those would be my guesses.
steve
/ shear pin breakage #6
steve
/ shear pin breakage #7
I've seen ratings for shear pins from grade 2 to grade 5 bolts. 5 seems high, but some manufacturers use them in their equipment. I would suggest, since this is happening in only grass, that your mower requires a higher grade shear pin. If you're using a 2 trying going to a 5 and see if that fixes it.
Of course, you should check the mower's manual first to see what they recommend. My Howse mower uses a grade 5.
John
/ shear pin breakage #8
John
/ shear pin breakage #9
I would go with your blades are not swinging out like they should... Take a look under the cutter and see if they are "out" before hitting the PTO and if the pin breaks again, before you do anything look under the mower and see where the blades are AFTER the break.
Maybe you have your RPMs to hight when turning the PTO on?
When I got my tractor and mower the dealer right there on the lot broke a pin showing me how to turn on the PTO. Well he set the RPMs to 1100 or so when that happen. So what I have done, is turn on the PTO at idle speed and I have never broken a pin.
/ shear pin breakage #10
/ shear pin breakage #11
Toby - the 4720 has two PTO speeds; 540 rpm and 1000 rpm.
Are you positive you're mowing at the 540 rpm setting? Because spinning those heavy blades at 1000 rpm PTO speeds can be real hard on a 1/2 shear pin - even if you DON'T hit anything
//greg//
/ shear pin breakage #12
//greg//
/ shear pin breakage #13
I have never broken a shear pin on this mower. Check out the photo. The yellow slip clutch is pretty cheap at agrisupply.
/ shear pin breakage #14
Snapped another one after hammering the last one out. Mowing a previously mowed field. PTO is right speed, not hitting anything. Slip clutch? Does it still require a shear bolt?
Toby
Toby
/ shear pin breakage #19
Swinging that wheel up saves me from a big overhang and the potential legal hassles with that. I trailer a lot of miles and like having that wheel swung up. The tailwheel doesn't pivot around either, it just sits there.
The slip clutch is held on by the former shear pin. You use a strong bolt though so that it won't shear. I ordered my RC with it so I didn't have to do the install but the PTO shaft might need to be shortened a little.
This doesn't explain why the poster's shear bolts are shearing so easily though.
/ shear pin breakage #20
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
