SHEAR BOLTS
/ SHEAR BOLTS #11
Some tractor hyd PTO's are hard on shear pins, too. Mahindra had to put an accumulator tank [ small tank in line between the electric hyd solenoid and the hyd PTO clutch pack ] to ' calm down ' the abrupt engagement of the PTO in tractors like mine. Folks that have a foot operated clutch for the PTO, can bring it in slowly manually. Like my old John Deere 2240.
/ SHEAR BOLTS #12
Sheer bolts dont require a lot of torque and should be torqued to spec, otherwise they are weakened right off the bat at install. On my blower it's only 12 lb/inch
/ SHEAR BOLTS #13
I would NOT 'upgrade to a grade 8 bolt. I can see upsizing a bit to imperial for convenience. Remember the shear pin is protection against damage to expensive structure. Shear pins generally should not be in any tension and the hole should be a tight fit to eliminate bolt bending.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
