shear bolt revisited!!!!!!!
   / shear bolt revisited!!!!!!! #21
My MK Martin 75" snowblower specifies different grades for bolts. The auger shear bolt is a 5/16" grade 2 while the Italian made Comer driveshaft which powers the blower and auger is a 10mm class 8.8. Metric 8.8 is similar to SAE grade 5 while metric class 10.9 is similar to SAE grade 8.
The metric class rating gives the actual tensile and yield strength for the steel as shown here:
Metric Class 8.8 Hexagon Bolts & Nuts 12mm AF
   / shear bolt revisited!!!!!!! #22
I have always used grade 5 for years.
I get them by the 25's and my blower is none the worst, in fact only problems I ever had was using softer 'hardware store' bolts.
The softer bolts bend and mushroom the ends while the grade 5 shear nice and clean and less often.
Once in a bind I used soft bolt and actually had to drill it out.
Chunks of ice shear soft bolts while it takes a stone to shear a grade 5. (and generally it is one that gets wedged between the fan blade and housing.)
   / shear bolt revisited!!!!!!! #23
KCO-
I agree with you, I emailed MK Martin after I bought my MK68 blower and they responded exactly as you have quoted.
John Deere 50 (A60462)
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
Stout Brush Grapple (A59814)
Stout Brush...
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
Kubota RTV X900 (A53317)
Kubota RTV X900...
