shear bolt revisited!!!!!!!
/ shear bolt revisited!!!!!!! #21
My MK Martin 75" snowblower specifies different grades for bolts. The auger shear bolt is a 5/16" grade 2 while the Italian made Comer driveshaft which powers the blower and auger is a 10mm class 8.8. Metric 8.8 is similar to SAE grade 5 while metric class 10.9 is similar to SAE grade 8.
The metric class rating gives the actual tensile and yield strength for the steel as shown here:
Metric Class 8.8 Hexagon Bolts & Nuts 12mm AF
/ shear bolt revisited!!!!!!! #22
I have always used grade 5 for years.
I get them by the 25's and my blower is none the worst, in fact only problems I ever had was using softer 'hardware store' bolts.
The softer bolts bend and mushroom the ends while the grade 5 shear nice and clean and less often.
Once in a bind I used soft bolt and actually had to drill it out.
Chunks of ice shear soft bolts while it takes a stone to shear a grade 5. (and generally it is one that gets wedged between the fan blade and housing.)
/ shear bolt revisited!!!!!!! #23
KCO-
I agree with you, I emailed MK Martin after I bought my MK68 blower and they responded exactly as you have quoted.
3pt Bale Spear (A64127)
3pt Bale Spear...
2017 FORD F-750 SUPER DUTY (A65643)
2017 FORD F-750...
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
Luck Now 425 (A64126)
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
6' 3Pt Disk (A66285)
