shear bolt revisited!!!!!!!
/ shear bolt revisited!!!!!!! #21
My MK Martin 75" snowblower specifies different grades for bolts. The auger shear bolt is a 5/16" grade 2 while the Italian made Comer driveshaft which powers the blower and auger is a 10mm class 8.8. Metric 8.8 is similar to SAE grade 5 while metric class 10.9 is similar to SAE grade 8.
The metric class rating gives the actual tensile and yield strength for the steel as shown here:
Metric Class 8.8 Hexagon Bolts & Nuts 12mm AF
/ shear bolt revisited!!!!!!! #22
I have always used grade 5 for years.
I get them by the 25's and my blower is none the worst, in fact only problems I ever had was using softer 'hardware store' bolts.
The softer bolts bend and mushroom the ends while the grade 5 shear nice and clean and less often.
Once in a bind I used soft bolt and actually had to drill it out.
Chunks of ice shear soft bolts while it takes a stone to shear a grade 5. (and generally it is one that gets wedged between the fan blade and housing.)
/ shear bolt revisited!!!!!!! #23
KCO-
I agree with you, I emailed MK Martin after I bought my MK68 blower and they responded exactly as you have quoted.
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
