Shaving Concrete
/ Shaving Concrete #1
htiek126
Southern Maryland
Iseki TA270F, Yanmar YM1510D, Mitsubishi MT2201D
A little off topic, but my neighbor had a contractor extend the exterior walls of the house for three rooms. The bonehead poured the concrete as much as 1.5" higher than the existing concrete slab, and then quit the job. The addition is now under roof and they are planning to install hardwood. Does anyone have an idea of how to efficiently reduce the height of the concrete? It mostly needs to be knocked down in the middle of the rooms. The new exterior walls are sitting on the slab and the slab is the right height under those walls.
/ Shaving Concrete #2
It can be ground down, but it is a messy, noise, and dirty job. Look for someone that does terrazzo tile work. They have the equipment, but they are also expensive. It might be cheaper to cut out the areas that are too high and have them re-poured. A difficult job no matter how they attack it...
/ Shaving Concrete #3
"The new exterior walls are setting on the concrete slab"
And some people wonder why we have building inspectors controlling our lives!!! Things like this make them necessary, sorry to say.
That wouldn't be an acceptable building practice around where I am. My guess is he is up the perverbial crick without a paddle. If the walls were on conventional foundations, then the high floor could be busted out, and a new floor poured. Don't see any easier way to do it.
/ Shaving Concrete #4
That does sound like an unusual building procedure. Not sure it was right in the first place, that you can fix it.
--->Paul
/ Shaving Concrete #5
Swami Ken sees a big concrete saw cutting out the centre area, jack hammer breaking it up and wheel barrow loads of cement being poured. /forums/images/graemlins/cool.gif
/ Shaving Concrete #7
The only reason that I can see that they couldn't raise the low points to be level with the high points is the ceiling hight and the fact that it is wood framed and they would have to protect the wood where it meets the concrete. Personally, I would put a pressure treated 2 x 4 around the walls and pour a top coat to level it using high strength fiber glass reinforced light weigh concrete and live with a lower ceiling hight. There are other remedies, but this is one of those cases that it would be helpful to visit the site to determine all the possibilities. It will take some creative imagination to resolve this, but it can be done. It will also cost some $$$$$ to do it correctly..
/ Shaving Concrete
The low points can be raised, however, that is almost the entire downstairs. The high points are limited to two 6 foot wide slabs with most of the really high stuff near the interface of the old and new slab. Tearing the entire slab and rebar up is certainly a solution, however, I was tyring to determine a better solution. Perhaps there is a happy medium in tearing out the highest spots and raising the surrounding areas to taper into the slightly high spots. Perhaps a concrete saw on a level guide could be used to saw level lines every inch or so. And use a jack hammer sideways to chip out the sections...
/ Shaving Concrete #9
first id be worried about the foundation as well as the correct thickness and depth of the footings if the contractor didnt know enough of how concrete work is done he may have done these wrong as well causing a bigger problem i suggest you tell your friend to get a structual engineer out to the site to evaluate it and he will more than likely have a resolution to the issue if he sees that the foundation and or footings are correct
/forums/images/graemlins/wink.gif
/ Shaving Concrete #10
Having made many mistakes in the past rectifying errors is not new to me.
On the original approach one will try to fix the error by using alternate methods that will appear to be the quickest and cheapest. This may work but usually takes a lot of time a leaves a less than desirable result.
On the second approach the first repair job is touched up.
Finally; common sense kicks in and the offending areas are removed and rebuilt from scratch. On the final analisis this will usually be the cheapest and fastest approach.
Egon
/ Shaving Concrete
The footings and foundation are good. He failed the footing inspection twice, and then finally he got it right. He peeled off the siding on the house before pouring the concrete, but he was not smart enough to peel off some of the foam sheathing and match the height of the existing slab.
/ Shaving Concrete #12
there is a machine that will grind the concrete down. they have them at a lot of the rental yards around here but it is noisy and time consuming
/ Shaving Concrete #13
Sounds like ripping the whole thing out and starting from scratch would be the way to go. Have him talk to the contractor about his status of bonding, insurance, and licensing. Maybe also talk to his attorney...
Another way to 'fix' is to use high-strength reinforced concrete to raise everything to the same level, and then cut all the 2x4's so that the roofline and ceilings match up with the existing structure. Any way he does it, it's a pain.
/ Shaving Concrete #14
Sounds like he is not the person to go to again, if you want it right!
I'm a little confused, you talk about slabs, and you talk about footers. Around 'here' most all houses have full basements. Footers/ foundation below frost line are required, altho lots of out-building are made on floating slabs. Not sure exactly what you have there.
Any dairy in your area? There is sure to be some concrete groovers nearby, they have a lot of equipment that will chew up concrete. Messy & noisy!
--->Paul
/ Shaving Concrete #15
How thick is the slab he poured. If it's a 4" slab I wouldn't be taking 1.5" off it and not expect cracks. Plus, by the time you shave that off you'll probably be into the rebar or mesh. Sounds like a live with it or a r&r.
/ Shaving Concrete
We do not have basements because the water table is too high. Many houses are built with footers, block, and then a concrete slab that sits on the block or a crawl space with floor trusses or joists on the block.
/ Shaving Concrete
I saw the prep work before the slab was poured, and the concrete that is too high is in excess of the 4" slab thickness.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2008 Case IH JX80 Loader Tractor (A66285)
2008 Case IH JX80...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
2018 Case TV380 (A64126)
2018 Case TV380...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
