Sharpening Brush Hog Blades
/ Sharpening Brush Hog Blades #1
DTCOOPER
Bullard, TX
02 CIH D33
Well, this is assuming that you guys are able to help me get my stump jumper off the deck.. :)
I need some directions on sharloening the blades. They are not in horrible shape, but a few nicks chipped out of the leading edges. I have heard that they are not supposed to be "sharp", but more just "square"..
Can you guys give me some pointers ? I have all tools necessary I believe.. Just lack the know how to get it done..
Thanks again,
Daniel
/ Sharpening Brush Hog Blades #2
Block the mower up when you are working under it.
You should have an access hole in the top to get to the blade bolts. Rotate the gear box by hand until a bolt is aligned with the hole and remove the nut using your 3/4" drive socket with breaker bar. The bolt is keyed so don't let it drop down and skip. I put a jack under the bolt if the nut is not turning freely and the bolt wants to drop. The stump jumper stays in place - you just remove the blades.
Once the blades are off they can be sharpened with any grinder. I prefer a 9" angle grinder.
I have also sharpened the blades by tilting the mower on it's side and leaning it against a post or something to sharpen the blades without removing them.
Make sure the blades end up the same weight and shape for balance. Put them on nice and tight making sure the keyed bolts are aligned properly. I use a 3' cheater.
Grease it and check the gear oil while you are working on the mower.
Here is the KK manual. They don't really address sharpening but there is other good info.
http://www.kingkutter.com/downloads/manRKRK.pdf
Brad
/ Sharpening Brush Hog Blades #3
Brad did a pretty nice job. It's preferable to leave the blades on as they can be a real chore to take off. Then again, if you do take them off - be sure to use some never sieze when you put them back on.
I have sharpened blades on the cutter by just lifting it with the 3pt all the way, blocking it with 4 (yes 4) jack stands and 2 6x12x2' blocks of wood next to me. Just in case it drops off the jack stands. A Dremel tool, die grinder or even a file and elbow grease work.
For cutting brush and small trees, you want to leave 1/16 to 1/8" of flat verticle on the "edge" of the blade. The 1/16 is for doing brush and tall thick grass. The 1/8 is for doing smaller trees. Less damage to the blade and more damage to the stump. You WANT to shatter the stumps to keep them from growing back. A sharp cut stump will re-sprout into a cluster.
good luck!
jb
/ Sharpening Brush Hog Blades #4
After taking the blades off, I decided it's a lot easier to sharpen them on the cutter. I raise it up on the 3PH and block it securely, and use a 4 1/2" angle grinder, which is light enough to hold in one hand while steadying the blade. As the others said, there's supposed to be a slightly blunt edge.
/ Sharpening Brush Hog Blades #5
So, why not make the blades sharp. I had not heard of this before.
Also, I have used my FEL or Pallets Forks to lift mine up on its end to sharpen...
/ Sharpening Brush Hog Blades #6
If the blades are too sharp they will leave a sharp cut and puncture a tire and if they are a little dull/blunt they will bust it up and wont puncture tire
/ Sharpening Brush Hog Blades #7
I don't take anything off. I just chain my cutter to the FEL, raise it up until it is standing it on one side leaning back against my FEL, and have at it with an angle grinder. Much easier to me than having to reach under it. And my blades typically stick to the stump jumper over the winter (pic 2) so I have to free them up and oil the pivot (pic 3).
okay my blades are considerably more boogered up than yours.. Should I just go ahead and change the baldes and start with new ones ?
/ Sharpening Brush Hog Blades #9
Most blades on 5' & 6' cutters are pretty healthy and can be sharpened many times. Personally I like a sharp edge but at a very steep angle - this gives me the cut I want for my grass plus will shatter larger stuff and hold an edge a little longer. Dings from rocks etc. won't be as deep into the edge with a steep angle too, a little easier to grind out. I use my hyd. toplink to kick the rear of the cutter up high, put a jackstand under it, then clamp a pair of Vise-Grips on the end of the blade and let it rotate against the body to hold the blade while I grind it with my 4 1/2" grinder. No need to try and balance your blades with just a simple sharpening, if you have to remove enough metal to throw your cutter out of balance to where you can detect it, it's time for new blades !!!
/ Sharpening Brush Hog Blades #10
My blades are not quite as nice as they appear in the pictures. They have been sharpened several times. But they are so heavy that I don't think that occasional sharpening is having much affect on the balance. If I have to grind one to get a notch out, I try to grind the other an equal amount. I figure when I start to notice some vibration, it will be time to get new blades.
/ Sharpening Brush Hog Blades #11
I always sharpen them on the mower. We have 2 bush hogs and a finnish mower at my buddies property where I keep the tractor. My bush hog is an old 5' JD that is beat to heck, It is used for true bushhogging, trees, making trails, and such.We keep the blades dull on it to prevent tire killing spikes. The other bushhog is the one we use on pastures and "clean" land. Its fairly sharp but not mower blade sharp. The finish mower is used only on property that we have mowed before and is treated like a finish mower. If you only have one mower it depends on what you are doing with it as too how sharp you want it. Tires are expensive and if you are clearing land all it takes is one spike to wreck your whole day.
/ Sharpening Brush Hog Blades #12
As mrjimi said.. a sharp blade will make tire-poking spears out of small stumps ( 1" or so ).. whereas the duller blade 'shatters the stump. An added benefit is that a shattered stump usually kills the bush or tree.. On the other hand.. a neat cut sometimes acts like a pruning, and allows the stump to live and put off shoots and start all over again.
3rdly, a sharp blade gets more heavilly abuse by rocks and other debri.
generally you just hit it with a file or grinder to fix big nicks, and put a 1/8 or 1/16 edge on it and go.
Some people use a rotary mower to cut 'extended' yards.. and in doing this it is ok to put an edge on the blade like a lawnmower as there is no brush to cut. This gives a pretty good cut.. just a tad bit shaggier than a rider lawnmower.
Soundguy
/ Sharpening Brush Hog Blades #14
Haven't taken my blades off in 24 years. I sharpen them with a Dremel tool that has a small round grinding stone on the end, does a good job.
/ Sharpening Brush Hog Blades #15
I've never sharpened my blades on a shredder or even my lawn mower. Seems to always cut fine.
/ Sharpening Brush Hog Blades #16
Sharp lawnmower blades help the engine work less and make a healthier cut for the grass.. cuts it vs ripping it/...
Soundguy
/ Sharpening Brush Hog Blades #17
Using an impact wrench, I can change out (remove/reinstall if sharpening) blades a matter of minutes, sometimes using the 3-pt to lift it off the ground and other times using a chain hoist. Regardless, it's just two bolts/nuts.
As far as sharpening, I like to have a nice sharp cutting edge if I'm "mowing" pastures that have already been cleared and I like much duller blades for brushcutting for all the reasons already mentioned.
/ Sharpening Brush Hog Blades #18
Yowzers!
Either you have some short and stubby blades or you don't hit many large hard objects. My blades are lucky to still be with me in 24 months!
jb
/ Sharpening Brush Hog Blades #19
Soundguy
:) LOL,,, christ, I learn something new from you guys everyday. Was just out brushhogging the property today, and never had a clue as to the sharpness/dullness of rough cutter blades, and the reasoning behind it.
Thanks again fellas,, another day, another rookie lesson for me !!
/ Sharpening Brush Hog Blades #20
I have a 10' cutter. Any suggestions on how to get under it to sharpen the blades. If I put it up on end it will stand over 10' tall and oil is going to run out and I can't remember if it is just 90w gear lube or is there something special to put in it? Anyone sharpened one that big?
4004SFL (A59228)
4004SFL (A59228)
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
2008 TOYOTA Camry Solara Convertible (A61569)
2008 TOYOTA Camry...
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
2006 Sterling L9500 Grapple/Storm Truck, VIN # 2FZHAZCV36AV19376 (A61165)
2006 Sterling...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
