   / Share Pics of People Hauling or Towing Something Wrong #22,751
Same here. Even half standing up in the cab, I can't see the hitch over the hood to line it up for hitching.
It's "on" the ball now.
I even tried a flipped over drop hitch, which helps a little bit, but still almost impossible to line up without getting out first.
   / Share Pics of People Hauling or Towing Something Wrong #22,752
I guess that's the advantage of having a small tractor. I can see the hitch on mine easily. 😁
   / Share Pics of People Hauling or Towing Something Wrong #22,754
I have a wireless camera setup in my Branson that works fairly well.
There is no way I can even start to see the forks from the seat,
the camera has it's own battery power supply.
   / Share Pics of People Hauling or Towing Something Wrong #22,755
View attachment 3798316View attachment 3798319
I need that. Any recommendation on brand and model would be appreciated, even if it's just knowing ones to avoid.
   / Share Pics of People Hauling or Towing Something Wrong #22,756
That one is a Tadibrothers setup with a large monitor, and the battery pak for the wireless camera. The screen along with the magnetic mounted camera and magnetic battery pak are very handy and work well. I had an issue a while back with a battery pack that failed and their customer service and so called warranty P.O'd me so much I have resorted to trying different ones.
I got this one this spring to use as a backup camera on my trailer and while it's not quite the resolution of the much more expensive unit it seems to work well the few times I've used it. Normally I back the trailer around just using mirrors but occasionally it is very handy to see behind it in tight spots.
   / Share Pics of People Hauling or Towing Something Wrong #22,757
I have a similar unit;
I very seldom use it, and I quickly found out that I needed to use my camera when trying to hook up to it.
View attachment 3797669View attachment 3797670
It wouldn't help on yours, but on the more open style like mine, I find it's helpful to raise the loader up, then tilt the hitch forward. That way, I can look through the framing and see the hitch ball to line up. Once under the hitch, just raise the loader and curl back.
   / Share Pics of People Hauling or Towing Something Wrong #22,758
I have a 2" receiver welded to the inside top of of my FEL. Works great, and I can see the ball when I hook up a trailer. And the big advantage of the front mounted Hitch is that you have very precise control over the trailer.
I don't use it for towing trailers over any distance at all. Just for removing the trailers around and driving from one property to another less than a mile or so.
I suppose I could weld another receiver to the top of my snow thrower for towing in the winter, but I don't think I would like to use the backhoe to tow something with a ball. Too much risk of damage or tipping.
   / Share Pics of People Hauling or Towing Something Wrong #22,759
In the interest of never-ending product improvement, I even made up a slide-on front quick-hitch mirror.
It works, but not worth the effort to install/remove.
   / Share Pics of People Hauling or Towing Something Wrong #22,760
Great minds think alike? I did the same for my pallet forks. And like you, found it works great, but would require a pretty big job of moving a lot of pallets to make up for the time lost in setting it up and re-adjusting the mirror positions.
Bolt Cutters (A57454)
Aluminum Turtle (A57454)
Aluminum Turtle...
17102 (A56859)
17102 (A56859)
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
Cargo Van (A59230)
Cargo Van (A59230)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
