   / Share Pics of People Hauling or Towing Something Wrong #22,761
That one is a Tadibrothers setup with a large monitor, and the battery pak for the wireless camera. The screen along with the magnetic mounted camera and magnetic battery pak are very handy and work well. I had an issue a while back with a battery pack that failed and their customer service and so called warranty P.O'd me so much I have resorted to trying different ones.
I got this one this spring to use as a backup camera on my trailer and while it's not quite the resolution of the much more expensive unit it seems to work well the few times I've used it. Normally I back the trailer around just using mirrors but occasionally it is very handy to see behind it in tight spots.
It looks like all of these systems run about $60 for the camera and monitor, and then another $60 for the battery(s). :ROFLMAO: I say that, because the median price for 12V units powered off a cigarette lighter jack is about $60, and the median price for the rechargable battery-powered versions is right around $120.
   / Share Pics of People Hauling or Towing Something Wrong #22,762
my "better" system was much more then that :(
default-user=s40-p
Jul 12, 2023, 3:03 PM
Hello again and thank you for shopping at Tadibrothers.com​
Your order 145165 has been shipped via OSMWorldwide
You can also track your order by clicking on the tracking number
or online at our homepage using your e-mail address.
Please note that your tracking number may require several hours to update in the carrier's system before it will track properly and will not update until Monday evening for orders placed over the weekend
Order Details
Order # : 145165
07/04/2023 10:45AM
Billing and Shipping Information
Shipping AddressBilling Address
Order Content
SKUItemQtyPriceTotal
SKU90121Heavy Duty Digital Wireless Backup Camera with Monitor featuring 175ft Range and Audio
* 6 Hour Battery Pack (For 1 Camera)
$79.99
* 9-Inch Digital Monitor
$49.99
* 120° Heavy Duty RV Camera (Digital Wireless)
$159.99
* FR_NV
$0.00
1$494.99$784.96
SKU4987976Magnets for a Single Backup Camera2$19.99$39.98
Subtotal :$824.94
Shipping :$0.00
Discount :%%DiscountTotal%%
Tax :$0.00
Grand Total :$624.94
websales@tadibrothers.com
ACg8ocI5mEvHbhUygY14kC-sd22S6HRIf0q_ziH11v1qEH0n1dyo2A=s40-p-mo
   / Share Pics of People Hauling or Towing Something Wrong #22,763
I just bought a solar/rechargeable unit off Amazon. $100 even. I did not spend a whole lot of time researching, but they all seem to be 1080p, and have some sort of night mode enhancement (likely cheap infrared LED’s). So I chose one with a magnetic mount on the camera, suction-cup mounting for the screen, and a larger than average battery capacity. It can recharge via solar, or by plugging it in to the wall, as my tractor is stored indoors.
I’ll be loading another two pallets onto a truck today, approximate value is $23,000/each, so some care is involved. A camera will be much-appreciated in this operation.
   / Share Pics of People Hauling or Towing Something Wrong #22,764
I'd just get a set of these. Telescope the receiver side a few inches longer so you know that you are under the trailer side if you line up your balls just as the picture shows.
   / Share Pics of People Hauling or Towing Something Wrong #22,766
I had a ruff time hooking up the trailer one time long ago. When I finally got it hooked up, I drove straight forward a few yards and put an old magnetic-mount C.B. antenna on the tongue of the trailer.
Then I sat in the truck and looked in the center rear view mirror to see the antenna. I marked the spot on the top of the truck tailgate with a 1" wide strip of white duct tape.
It works pretty good but I bet the 2 balls would be better for depth perception.
   / Share Pics of People Hauling or Towing Something Wrong #22,767
The door of the truck read some landscaping company
depending on bumps in the road at some point that was certain to be more than 4' past the bumper... and probably dragging at other times.
   / Share Pics of People Hauling or Towing Something Wrong #22,768
Yes, the balls give you up and down if you are using an FEL, in addition to side to side. Not as important if you are hooking up to the same pickup receiver as when you unhooked the trailer.
On a FEL, fork frames with a built in receiver as Slowpoke has sure are convenient.
   / Share Pics of People Hauling or Towing Something Wrong #22,769
Viagra might have helped.
2007 FREIGHTLINER COLUMBIA 120 (A58214)
2007 FREIGHTLINER...
2870 (A58376)
2870 (A58376)
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2021 SANY SY365C9C5K (A58216)
2021 SANY...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A58214)
2012 TROXELL...
