   / Share Pics of People Hauling or Towing Something Wrong #11,421
An errant strap can cause a lot of damage!
   / Share Pics of People Hauling or Towing Something Wrong #11,422
Why would that be sad?
At least in that case some innocent bystander was not hurt by the cluster f...
Sad because the loader did not learn a thing. The next time could be the problem and hopefully there are no innocent victims.
   / Share Pics of People Hauling or Towing Something Wrong #11,423
I guess I just don稚 agree with your premise that it痴 a sad thing that it didn稚 happen so you can state it the way you see it and I値l read it the way I see it
   / Share Pics of People Hauling or Towing Something Wrong #11,424
The fact you can see how badly chafed/cut that strap is from the rub rail is why I generally dont use them anymore. I got similar wear on the dull bumper of my L3200 in a quick test haul. Decided it would be easier to chain rather than make sure my straps would never rub. Add in the fact a dull rub rail will do that when you loop to keep the hook from popping loose & it just reaffirms my decision.
Straps are usually faster, & I've thought about getting some with 2' of chain & latching hooks on the ends. But it's probably not worth it for only part time use.
   / Share Pics of People Hauling or Towing Something Wrong #11,425
I rarely haul anything big, but since a friend gave me some heavy duty straps with the chain ends, I have never used a chain and load binder again.
   / Share Pics of People Hauling or Towing Something Wrong #11,427
Re post 11376, my brother did that with a light sports car (non running and winched out of a shed) loaded tail first and snugged up hard on the front bar of the deck. However he only jack knifed it and put a massive dent in the right rear side panel on the family car.
   / Share Pics of People Hauling or Towing Something Wrong #11,428
Re post 11391, JCB Fasttrack, if you hit the motorway, how many idiots would chase you to have a closer look, and/or overtake you?
   / Share Pics of People Hauling or Towing Something Wrong #11,429
I use straps 2 inch straps frequently, however I feared friction would eventually cut thru from sharp edges.
My solution was to cut wear sleeves that I position wherever there is sharp edges.
Old fire hose is great for that purpose.
The fire hose found in most commercial buildings is 1 1/2 inch and fit my 2 inch binders nicely.
   / Share Pics of People Hauling or Towing Something Wrong #11,430
..........The fire hose found in most commercial buildings is 1 1/2 inch and fit my 2 inch binders nicely.
Don't they get sorta miffed to find it missing?
WACKER NEUSON LIGHT TOWER (A58216)
WACKER NEUSON...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2013 EZ-GO RXV Golf Cart (A57453)
2013 EZ-GO RXV...
