   / Share Pics of People Hauling or Towing Something Wrong #11,421
An errant strap can cause a lot of damage!
   / Share Pics of People Hauling or Towing Something Wrong #11,422
Why would that be sad?
At least in that case some innocent bystander was not hurt by the cluster f...
Sad because the loader did not learn a thing. The next time could be the problem and hopefully there are no innocent victims.
   / Share Pics of People Hauling or Towing Something Wrong #11,423
I guess I just don稚 agree with your premise that it痴 a sad thing that it didn稚 happen so you can state it the way you see it and I値l read it the way I see it
   / Share Pics of People Hauling or Towing Something Wrong #11,424
The fact you can see how badly chafed/cut that strap is from the rub rail is why I generally dont use them anymore. I got similar wear on the dull bumper of my L3200 in a quick test haul. Decided it would be easier to chain rather than make sure my straps would never rub. Add in the fact a dull rub rail will do that when you loop to keep the hook from popping loose & it just reaffirms my decision.
Straps are usually faster, & I've thought about getting some with 2' of chain & latching hooks on the ends. But it's probably not worth it for only part time use.
   / Share Pics of People Hauling or Towing Something Wrong #11,425
I rarely haul anything big, but since a friend gave me some heavy duty straps with the chain ends, I have never used a chain and load binder again.
   / Share Pics of People Hauling or Towing Something Wrong #11,427
Re post 11376, my brother did that with a light sports car (non running and winched out of a shed) loaded tail first and snugged up hard on the front bar of the deck. However he only jack knifed it and put a massive dent in the right rear side panel on the family car.
   / Share Pics of People Hauling or Towing Something Wrong #11,428
Re post 11391, JCB Fasttrack, if you hit the motorway, how many idiots would chase you to have a closer look, and/or overtake you?
   / Share Pics of People Hauling or Towing Something Wrong #11,429
I use straps 2 inch straps frequently, however I feared friction would eventually cut thru from sharp edges.
My solution was to cut wear sleeves that I position wherever there is sharp edges.
Old fire hose is great for that purpose.
The fire hose found in most commercial buildings is 1 1/2 inch and fit my 2 inch binders nicely.
   / Share Pics of People Hauling or Towing Something Wrong #11,430
..........The fire hose found in most commercial buildings is 1 1/2 inch and fit my 2 inch binders nicely.
Don't they get sorta miffed to find it missing?
excavator trenching bucket- one bucket per lot (A56436)
excavator...
JCB 2145 (A47477)
JCB 2145 (A47477)
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
